Shock tower bolts?
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Looking in the engine compartment, there are bolts coming through the shock tower on both sides. Is the inner part, (engine side), removeable by unbolting these? What part would I order, if so? Some ding-a-ling has drilled the typical holes there to grease the upper control arms because they didn't want to spend lunch money on right angle fittings.
If I understand what your asking, those are welded in and the small bolts you see hold the spring cover on thats behind the wheel. Back in those years I saw alot of those that had the holes burned in by a cutting torch to grease the upper arms. There was a kit that we used at the ford dealer where you took the grease plugs out and stuck a round little roller wheel thing in to grease the uppers. Most of the time you couldnt get a 90 degree zert in there. The car I have now has been hammered out a little to clear the ones I have in it.
