shock ?
  • Thread starter Thread starter cheeks
  • Start date Start date Dec 3, 2004
C
cheeks
262
  • Dec 3, 2004
I'm getting ready to order a set of MM adjustable lowers, and have read that some people remove the rear quad shocks after putting on the lower control arms??...why is this done?...any advantage, and what about just running lakewood 50/50 in the rear?...If anyone can shed some light on this subject that would be great...thanx
NKau
1,346
Jefferson, WI
Dec 3, 2004
  • Dec 3, 2004
People remove the quad shocks so they can run a wider tire generally, and because they are pretty much useless once good lca's and adjustable uca's are installed. BTW; I'd put in adjustable uppers at the same time.
C
cheeks
262
  • Dec 3, 2004
Which brand of adjustable uppers should i get with the MM lowers?
NKau
1,346
Jefferson, WI
Dec 3, 2004
  • Dec 3, 2004
I should rephrase that; if you have traction problems, you might want to look into the uppers. They aren't absolutely necessary, but help eliminate inherent traction problems by helping correct pinion angle when properly adjusted.
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
