  • SN95 4.6L Mustang Tech
Shocks+ springs.......?
  • Thread starter Thread starter Warrior 102
  • Start date Start date Sep 28, 2006
Warrior 102
231
Macomb MI
Sep 28, 2006
  • Sep 28, 2006
Hey guys,How hard is to change the shocks and springs package on 99-04 mustangs, and what is all involved in the process, if anyone don this please explain.And what combo do you recommend for 1 1/2 or 1 1/4 inch drop.
Thanks
R
Rocketman
730
SoCal
Sep 28, 2006
  • Sep 28, 2006
If you want it slammed go with H&R SS. Moderate drop and good ride go with Eibach Pro-Kit.
This is by far the best how to article out there.
http://www.stangnet.com/tech/spring.html
nwapache
313
Seattle,WA
Sep 28, 2006
  • Sep 28, 2006
Its a piece of cake...nothing to be stressed about. Basic hand tools and a couple of hours (first time)
I can do mine now in just about an hour.
I'd recommend H&R
Barrier
155
  • Sep 28, 2006
Easy as balls... just don't be freaked out when the front springs pop out of their rust-encrusted lower seats... alls ya gotta do for the fronts is take off the calipers, disconnect the sway bar, then put a jack under the a arm and unhook the strut completely top and bottom... lower the a arm down slowly until the a arm is bottomed out. then pry the spring out
Back all ya gotta do is take off the calipers, jack under the diff, unhook the shocks and the small shocks (forgot what you call em... they reduce wheel hop I think), lower the whole rear end until it bottoms out, then pry out the rear springs. Lowered springs are a lot easier to put in because they're shorter and easier to compress... oh and don't forget to either change out or shave down your pinion snubber.
D-specs = kickass strut/spring combo... I swear by the Eibach pro kit springs.
Warrior 102
231
Macomb MI
Sep 29, 2006
  • Sep 29, 2006
anyone use tokico struts/spring combo,anyone any comment on this product?
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Suspension Spring I.D. help?
  • Scott_S
  • Aug 21, 2025
Fox 5.0 Mustang Tech Aug 21, 2025
Scott_S
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
