Short Belt?
I would take a wrench and drive to the parts shop and start with a 85" 6rib belt and then go from there. Your going to have to run the belt over the waterpump across the other side or it will rub against itself.
I am running a 76.5" belt, thats no smog only. I have ac and ps. I drilled a hole in the tensioner bracket, and rotated it. Not something I would recommend, but it has worked for years. The tensioner is running in the loose end of the range, and I get a little chirp when I start it up sometimes. Good for the bearings in the accessories though.
