short trow shifter Q? need your imput.....
Hey guys,witch short trow shifter is the most popilar for T45,and witch one you recomend?
by the way what you think about steeda tri ax?
thanks.
We've used the pro 5.0 short shifter several times. Works well, but remember that as you shorten the throw, the effort to shift necessarily goes up. I've seen several miss 2-3 because of that. These are not the best shifting trannys around.
I've got just over 110K miles on my T45 with a Steeda TriAx and like it just fine. Handle adjusts to two different heights, I personally like the taller position.
I'm waiting on a Hurst SST with chrome stick to come in right now, I like the look of the chrome stick better and just wanted to see how it compared to the Steeda.
Broken shift forks to boot...
I have the Tri-ax and it is OK but hear good things about the MGW shifter.
MGW hands down. Not only does it have the shortest throw. It's sturdy, smooth and you can rotate the handle 360 degrees. I had a Pro 5.0 and a Steeda before and out of the 2 I like the Pro 5.0 Better.
The Steeda was notchy, uncomfy and didn't feel sturdy. I have a T-45 and I love how the MGW feels, I've never missed the 2-3 shift and I can even chirp the tires doing so.
+1 for MGW, I had the Tri-Ax and hated it. Had the Pro 5.0 it was ok, hurst sucked. Thid MGW is a joy! It has stronger springs so finding third is a no brainer and the adjustable position puts the stick right in your hand.
Best shifter IMO
Pro 5.0 is my opinion. Ive tried the MGW, i liked it, but ive found that i shift alot better with the 5.0
I like it too. We use the heavy spring set rather than the light ones, so that hitting third is easy. Only problem is short throw = high effort, so you have to be sure and "shift it" else you "miss it"...
