Shortblock suggestion
Hi everyone,
I have a 1965 Ford Mustang running on original 289cu.in V8.. Initially I decided to re-build the original engine and purchased the parts mentioned in the below list.
However I changed my mind now and decided to swap the engine with shortblock.
I do need your suggestion.
Which shortblocks are compitable with my purchased list.
Which companies is really produced good shortblock, i mean is no problem. Somebody from forum suggest DSS Racing.
350+ hp is ok for me.
I am from Turkey, therefore i have no chance for wrong choose.
Regards
Part Number
Description
Web Address
AFR-1399
AFR 165cc SBF Street/Strip Outlaw Heads
Airflow Research (AFR) 1399 - AFR 165cc SBF Street/Strip Outlaw Heads - Overview - SummitRacing.com
AFR-6320
AFR Head Bolt Washer Kits
Airflow Research (AFR) 6320 - AFR Head Bolt Washer Kits - Overview - SummitRacing.com
AFR-6324
AFR Head Bolt Bushing Kits
Airflow Research (AFR) 6324 - AFR Head Bolt Bushing Kits - Overview - SummitRacing.com
ARP-100-1202
ARP Chromemoly Header Bolt Kits
ARP 100-1202 - ARP Chromemoly Header Bolt Kits - Overview - SummitRacing.com
ARP-154-6402
ARP High Performance Series Wave-Loc Connecting Rod Bolts
ARP 154-6402 - ARP High Performance Series Wave-Loc Connecting Rod Bolts - Overview - SummitRacing.com
ARP-154-7904
ARP Oil Pump Driveshaft Kits
ARP 154-7904 - ARP Oil Pump Driveshaft Kits - Overview - SummitRacing.com
ARP-254-4401
ARP Pro Series Cylinder Head Stud Kits
ARP 254-4401 - ARP Pro Series Cylinder Head Stud Kits - Overview - SummitRacing.com
ARP-254-5501
ARP Main Stud Kits
ARP 254-5501 - ARP Main Stud Kits - Overview - SummitRacing.com
CCA-19043-16
COMP Cams Ultra Gold Aluminum Rocker Arms
COMP Cams 19043-16 - COMP Cams Ultra Gold Aluminum Rocker Arms - Overview - SummitRacing.com
CCA-7754-16
COMP Cams Hi-Tech Pushrods
COMP Cams 7754-16 - COMP Cams Hi-Tech Pushrods - Overview - SummitRacing.com
CCA-K31-242-3
COMP Cams Xtreme Energy Cam and Lifter Kits
COMP Cams K31-242-3 - COMP Cams Xtreme Energy Cam and Lifter Kits - Overview - SummitRacing.com
EDL-4250
Edelbrock Aluminum Timing Covers
Edelbrock 4250 - Edelbrock Aluminum Timing Covers - Overview - SummitRacing.com
FEL-1415
Fel-Pro Performance Exhaust Header Gasket Sets
Fel-Pro Q1415 - Fel-Pro Performance Exhaust Header Gasket Sets - Overview - SummitRacing.com
FEL-35211
Fel-Pro Water Pump Gaskets
Fel-Pro Q35211 - Fel-Pro Water Pump Gaskets - Overview - SummitRacing.com
GMB-125-1420P
GMB High Performance Water Pumps
GMB North America 125-1420P - GMB High Performance Water Pumps - Overview - SummitRacing.com
HLY-0-80457S
Holley Model 4160 600cfm 4 Barrel Square Bore
Holley 0-80457S - Holley Model 4160 Non-Adjustable Float Carburetors - Overview - SummitRacing.com
HLY-12-289-13
Holley Mechanical Fuel Pumps
Holley 12-289-13 - Holley Mechanical Fuel Pumps - Overview - SummitRacing.com
HLY-12-803
Holley Fuel Pressure Regulators
Holley 12-803 - Holley Fuel Pressure Regulators - Overview - SummitRacing.com
MIL-18800
Milodon High Volume/High Pressure Oil Pumps
Milodon 18800 - Milodon High Volume/High Pressure Oil Pumps - Overview - SummitRacing.com
MRG-5807G
Mr. Gasket Ultra-Seal Head Gaskets
Mr. Gasket 5807G - Mr. Gasket Ultra-Seal Head Gaskets - Overview - SummitRacing.com
MRG-5831
Mr. Gasket Ultra-Seal Intake Manifold Gaskets
Mr. Gasket 5831 - Mr. Gasket Ultra-Seal Intake Manifold Gaskets - Overview - SummitRacing.com
MRG-5870
Mr. Gasket Ultra-Seal Valve Cover Gaskets
Mr. Gasket 5870 - Mr. Gasket Ultra-Seal Valve Cover Gaskets - Overview - SummitRacing.com
MRG-5890
Mr. Gasket Oil Pan Gasket Sets
Mr. Gasket 5890 - Mr. Gasket Oil Pan Gasket Sets - Overview - SummitRacing.com
MSD-31189
MSD 8.5mm Super Conductor Spark Plug Wire Sets
MSD Ignition 31189 - MSD 8.5mm Super Conductor Spark Plug Wire Sets - Overview - SummitRacing.com
MSD-8202
MSD Blaster 2 Ignition Coils
MSD Ignition 8202 - MSD Blaster 2 Ignition Coils - Overview - SummitRacing.com
MSD-8352
MSD Pro-Billet Ready-To-Run Distributors
MSD Ignition 8352 - MSD Pro-Billet Ready-To-Run Distributors - Overview - SummitRacing.com
SUM-163289
Summit Racing® OEM Harmonic Dampers
Summit Racing SUM-163289 - Summit Racing® OEM Harmonic Dampers - Overview - SummitRacing.com
WND-8020
Weiand Stealth Intake Manifolds
Weiand 8020 - Weiand Stealth Intake Manifolds - Overview - SummitRacing.com
KaraKedi,
I don't know what company to suggest, but given the parts that you have already purchased/collected, I would definitely make sure that whoever you purchase from, it should be a short block that is speced the same as a 65 289. Later model engines have different crankshaft balance factors and some fasteners (bolts, etc) were upgraded or changed to different sizes in later years as well as some gaskets and coolant passages in the blocks.
Just My Opinions,
Gene
The best advice I can give you is go to your local machine shop, they can probably rebuild your shortblock and save you money in the process. Let them know what parts you have and what you want out of it. If they have been in business long enough, they should have some good suggestions for you. Plus you deal locally and if you do have a problem out of it, perhaps you will have more luck getting it fixed. Also they are usually volume dealers of all the performance parts and may can get them for the same price or less that you can get from say summit or jegs.
If you are dead set on purchasing a short block, then good luck to you, there are numerous engine builders out there that all say they have the best product. The only thing i can tell you here is maybe go with a company like Blue Print....they are sold nationwide through reputable dealers like summit, you know they aren't some fly by night company and they seem to offer a quality product for a good price. Best of luck whatever you decide to do, again, my advice is go with someone local that has a good reputation.
