As some of you may remember, I had trouble about a month ago with my ignition module and when I finally got the car running again it sounded like a lifter was sticking. I put in some lucas oil along with an oil change, cleaned out the AIC, adjusted the idle and the sound went away. Well I made the hour and half trip up here to school today and everything was great. Then, I took about 10 minutes to get my stuff out of the car and left to make a quick Wal-Mart run. Right before I went to shift from first to second, I started hearing a weird rattling noise. It was pretty faint so I wasn't sure if it was even my car but sure enough it did it again before the shift to third. I've noticed it was only doing it at higher rpm's and this is the first time there has been any noise since last month. I'm hoping this was just from the long drive through all of the steep hills up here. Unfortunately, I don't have anywhere with light to check under the hood tonight so I'm hoping you guys can give me some input and ideas so I can sleep tonight until I can take a look tomorrow.
Also, I didn't notice any kind of loss in power, vibration, or jerking. My gauges show good oil pressure and normal running temperature. I tried checking the oil tonight and from what I could see, it was fine too.
