Should I get AFR emissions or NON emissions legal heads?
Starscream88
1,277
Park Ridge NJ
Being offered NON emissions legal heads,
I want them lol, But fear they may be a bad choice when inspection comes around
If I put back my stock H pipe with Cats (bear in mind my smog pump wont be operating as the heads have no holes for the pump)
Would I even stand a chance of passing emissions?
I dont want these heads to be more pain than there worth :(
Also is there any power differences between the two?
And how are AFR 185 heads?
Should I just go with the 185's?
Are there any power or price differences for heads with full emmissons capability? If not, get the emmissions legal heads.
The holes in the heads for the smog pump are only used when the engine is cold. Do a hot emmissions check and they will not be an issue. The visual check would be the only problem, and if you can bolt the tube up to the heads, that will get you by. The heads may not have to be drilled for full emmisions to bolt the smog pump air tube on the back of the heads.
I really dont think the people in the NJ state inspection facility know what there looking for as to the pipe behind the engine
The Non emissions heads have no EGR,
The middle of the head where the holes usally are (intake facing) are closed up
You think they would be ok?
