Should I....or Not
Black1987
my wife Bedazzled my input shaft
1,064
595
174
NC
Not a roller block, but :think::thinking:
Reactions: 1990slow50H
Just drill the holes for a spider tray. I have a new set of bones and a tray that I'll give you if you want. The link bar lifters are stupid expensive, unless you pick up a lightly used or new-used set off Corral of something. Then all you need is some hydraulic lifters. Unless I missed something and the blocks aren't the same...
I've learned a lot of where you can and can't pinch pennies on stuff like this - the hard way. You don't need a fancy bottom end, forged pistons, etc. I can cite 2 people off the top of my head that have been running a stock bottom end for 3+ seasons and are running high 8s and low 9s in the 1/4.
You DO need to buy a good valve train, good heads, a good fuel system and a good ignition system. Spend your money there.
If it's a non roller block, that won't work. the oil passages in the lifter bore area off. you need a set of retrofit lifters to use in that block to make it a roller.
Joe
Reactions: hoopty5.0
