  • SN95 4.6L Mustang Tech
should i remove my cats?
  • Thread starter Thread starter gwmcgowa
  • Start date Start date Mar 9, 2010
1 of 2 Next Last
G
gwmcgowa
25
  • Mar 9, 2010
i am going to be buying borla stingers i dont know if i should remove my cats or not because i like the sount with and with out them. i just dont want to screw anything up. i am driving a 2003 mach 1.
N
ninjastang125
591
maryland
Mar 9, 2010
  • Mar 9, 2010
By removing you mean off road xpipe, or cut your cats off your stock pipe? I would say yes from a performance stand point and it will make your exhaust note a bit louder.
trinity_gt
3,125
81
99
Canada
Mar 9, 2010
  • Mar 9, 2010
The power gain is minimal, the sound quality almost always worsens (IMHO) and depending on where you are, you may have issues later with passing emissions testing. You'll also need MIL eliminators or a tune to shut off the rear O2 sensors to prevent a MIL.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 9, 2010
  • Mar 9, 2010
sound is much better IMO (as long as you run mufflers) and if you can pass an inspection, i say do it!
D
Deleted member 38176
Mar 9, 2010
  • Mar 9, 2010
SaleenGT2001 said:
sound is much better IMO, i say do it!
40oz
499
Minneapolis
Mar 10, 2010
  • Mar 10, 2010
Modern cars without cats sound like ass, IMHO. Especially with straight-thru mufflers. You need 2" exhaust if you aren't running cats, and nobody makes that for our cars for a good reason.
You lose almost nothing with cats, and sound better. Not a big decision IMHO.
G
gwmcgowa
25
  • Mar 10, 2010
wow it seams pretty split! thanks for your input! i still will have to sleep on it..
M
MustangLife
1,285
Chattanooga, TN
Mar 10, 2010
  • Mar 10, 2010
My modern car with a x-pipe with mini cats and a Magnapack catback (straight-thru mufflers) gets alot of compliments.
ChillPhatCat
20+ Year Stangneter
Apr 22, 2002
409
65
48
Syracuse, NY
Mar 10, 2010
  • Mar 10, 2010
All I have to say about removing cats... pop pop crack pop crack pop pop
2000GTdriver
47
Mile High City, Colorado
Mar 10, 2010
#10
  • Mar 10, 2010
  • #10
I say keep the cats. But if you do remove them be sure to save them. Emissions testing came here with no warning and I sure with I had saved the parts I took off the old Pinto back then.
Rickyll7
718
#11
  • Mar 10, 2010
  • #11
What about weight? It's something to consider. Also, it wont sound bad with the right mufflers. There aren't really any bolt-ons that add tons of power so to say that removing the cats isn't a good idea because you wont gain that much doesn't make much sence. With that argument, the only mods that should be done are power adders and internals.
patman0911
2,287
Tuscaloosa, AL
Mar 10, 2010
#12
  • Mar 10, 2010
  • #12
I've been running without them for a while now but I've got mixed feelings about it and am considering welding in some high-flow cats sometime soon.
It sounds mostly good but it does get harsh and blatty right around 2200 RPM (that sound is my economy shift indicator ) and it's kinda loud, like, cringe when I fire it up in the morning while people are still sleeping loud, or, rolling through the neighborhood at 3am trying not to touch the gas pedal loud. It sounds kick-ass at idle and sub-2000 RPM cruise and it sounds glorious from 3000 RPM to redline at WOT but I would like to reign the volume in a little and I feel a little bad not running cats. The state of Alabama may not seem to care about emissions equipment but I thing they're a good thing in general as it's amazing how much cleaner the air is than it was 20 years ago. Mine's not too bad but you can start to smell it if you sit in a drivethru for any length of time and for all the headaches the CARB and federal government have caused for car enthusiasts, auto manufactures and the performance industry, it's really nice to be able to sit in rush hour traffic today with your windows down and not get a headache from all the exhaust fumes.
The factory h-pipes aren't as bad as they look, at least when they're not old and clogged up and as stated before, you're not really gaining a lot by losing them.
trinity_gt
3,125
81
99
Canada
Mar 10, 2010
#13
  • Mar 10, 2010
  • #13
Rickyll7 said:
W...so to say that removing the cats isn't a good idea because you wont gain that much doesn't make much sence.
It does if the cost (or potential cost) of gaining a few HP includes things like having your exhaust rasping during acceleration and popping and crackling every time the throttle is lifted (which might sound cool for about 5 minutes before wearing increasingly thin...), being stopped by police suspicious of the sound and being issued a citation for illegal emissions modifications, failing emissions testing and having to go to the expense and trouble of swapping in the OE pipe (and one had better hope he saved the OE pipe and didn't sell it on eBay...) and so on.
This particular modification carries risks and potential costs disproportionate to the gains than most other mods do. If you live in an area where emissions tests don't happen and think you can live with a raspy, poppy, crackly, unrefined-sounding exhaust then go for it. At the very least though, I'd recommend keeping the factory H-pipe around just in case you grow weary of the sound or an overzealous cop decides that you've committed a felony by willfully removing an emissions control device on your car...
Rickyll7
718
#14
  • Mar 10, 2010
  • #14
Good point. Agreed!
spederman
732
#15
  • Mar 10, 2010
  • #15
My first exhaust setup was bassani headers, O/R X pipe, and magnaflow regular catback. Sounded like crap IMHO. It was raspy , i couldnt pass inspection and had to pay for a hookup on a sticker, and not to mention the headache i would get from the fumes sitting at a stop light.
My new setup, i had bassani high flow cats welded back in, and changed to magnaflow mangapacks. It sounds soooo much better, it sounds like a nice tuned exhaust, instead of raspy,dumpy sounding. Plus I can easily pass inspection and no more fumes. I'm happy with this setup.
Modular2v
3,222
23
99
oklahoma
Mar 12, 2010
#16
  • Mar 12, 2010
  • #16
Ok Al Gore LOL.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Mar 12, 2010
#17
  • Mar 12, 2010
  • #17
lol what??? 2" exhaust? What are you talking about?
IMHO you gain a good power increase with no cats and it sounds a lot better. I guess if your an old man and you don't like anything moderately loud than you should stay away from a cat-less midpipe, but other than that i say O/R all the way...
Basicly its a matter of opinion if you think it sounds better or not. But as far as power, you definitely see some gains.
deftsound
Apr 6, 2004
945
Texas City TX
Mar 12, 2010
#18
  • Mar 12, 2010
  • #18
First of all i highly doubt its a felony. Secondly, ive Never ran cats and ive had 4 mustangs over the past 7 years and not once have i gotten pulled over for being too loud or not having cats. Now if your are running slp 1's and an o/r pipe yea its going to sound like crap but with a decent muffler like flowmaster, mac, borla, bassani it will sound awesome.
And third like i said previously its a matter of opinion whether it sounds better or not. Mine does not sound raspy in the least bit and neither does it sound poppy, crackly or unrefined.
trinity_gt
3,125
81
99
Canada
Mar 12, 2010
#19
  • Mar 12, 2010
  • #19
I believe that in most instances the Federal Clean Air Act makes the removal/disabling of a catalytic converter a felony and exposes one to a fine of up to $10,000. It's federal law one is breaking when one tampers with otherwise-functional cats on their car.
And for every anecdote of this nature there's one of a guy "harassed" for this very thing.
Again, anecdote. Yours may not, many do. In this thread spederman relates his combo was. The original poster deserves to know before heading down that path.
I agree that sound "quality" is a matter of taste. Fortunately, we all bring different perspectives to help the OPer make an informed decision. Some people think gaudy graphics and halo-headlamps and giant wings look good. Some people think the louder, the better. If nothing else, the OPer should know that not every subscribes to those sorts of schools of thought. I like patman0911's take on starting a super-loud car in a quiet neighborhood or having to tip-toe the throttle early in the morning because of stupid-levels of noise. Of course, like thinkers can be dismissed as being an "Al Gore" or an "old man" just as others can dismiss the noise/rasp-embracing crowd as ricey, immature and juvenile. Works both ways, right?
In the end it's up to the OPer to decide. Discussions like this will help him realize that the gains are nominal and the potential risks -- financial and sound-quality -- are real. Only he can decide if the benefits outweigh the risks.
deftsound
Apr 6, 2004
945
Texas City TX
Mar 13, 2010
#20
  • Mar 13, 2010
  • #20
True. Well then i recommend he go on youtube and listen for himself. I will say that anyone with SLP 1's and an o/r midpipe, thats rice. But a decent muffler with an o/r midpipe in most instances will sound good, IMO.
1 of 2 Next Last
T
Digital Tuning Hello OBD2 problem
  • TNmach1
  • Sep 18, 2026
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Tuesday at 10:14 PM
DangStitches
D
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
