  • SVT Tech Forum
Should I use friction modifier in the rear end?
  • Thread starter Thread starter O.D. Showtime
  • Start date Start date Feb 19, 2004
O
O.D. Showtime
820
  • Feb 19, 2004
I'm about to have my gears and the new girdle installed, I was just wondering if I should have the shop put friction modifier in the rear end, and if so, how much? Thanks.
103
597
Orange Park, FL
Feb 19, 2004
  • Feb 19, 2004
Absolutely, but I can't remember how much...
missouri_guy197
1,441
St. Louis, MO
Feb 20, 2004
  • Feb 20, 2004
Unless you are using a synthetic gear oil like Redline or Royal purple you absolutely need it...It takes a 4oz bottle of it then top the rest of the rearend off with gear oil...
C
Cobra X
130
Wilkes-Barre/Villanova, Pennsylvania
Feb 20, 2004
  • Feb 20, 2004
You need it unless you go with snythetic oil, which has it added already. You will be able to smell it a mile away in whatever auto shop you go to.
DCOBRA97
59
Bel Air MD
Feb 21, 2004
  • Feb 21, 2004
Absolutley agree with the above posts...........make sure you add the modifier, and or go the synthetic route.
L
Lo Pony
495
Atlanta, GA
Feb 22, 2004
  • Feb 22, 2004
See my website below - I did test several synthetic lubes with and w/o friction mod.... the only thing I can't attest to still is Redline's gear lube w/o friction mod, but I've "heard" it works fine.
but yes - use friction mod, 4 oz, no matter what the gear lube mfg. tells you - just to be safe. It won't hurt a thing.
TF
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
  • SVT Tech Forum
