Should the upper intake ever be too hot to touch?
GRGT1994
1,034
I just got my car back from the shop. They fixed my short/fuse issue. But now I seem to be overheating.
The mechanic said that it was running quite rich (expected since I put a FP and injectors in, and don't have a tune yet). So he adjusted the IAC (I believe) to lean it up a bit.
Well, I got all the way home running fine, but a little rough once I got home. Then I took it back out to drive it a bit more. And it ran really rough (didn't sit long enough to cool off in between).
So when I got back home the second time, I looked under the hood. Heat vapor trails are streaming off the engine, and the upper intake is freegin hot. WTF?
Does it sound like overheating? Stock engine temp gauge reads normal, and I had no pinging.
I'll be calling the shop tomorrow, of course, to find out exactly what they did to lean it up.
Any ideas?
Good damn question. Maybe he was talking about that other black box hanging off the throttle body? I don't know, I stopped listening when he said he got it running again. I'll obviously be following up on that tomorrow.
Yeah, obviously the guy has no idea what he is doing. What a douche.
And yes, intake should be hot. After all, the motor is hot, and aluminum conducts heat very well.
You can take a infared thermometer and check the temp of the block when it's warm. That will tell you if your gauge is working still.
Where is this "vapor" coming from exactly. Please ellaborate.
Scott
The TPS? lol, don't think that'll be effecting a/f ratio either.
Wait a second. The IAC controls the amount of air allowed into the engine at idle, right? That's why it's called the "Idle Air Control." So how does that not affect the air fuel mix at idle?
I'm no master mechanic (not even a good hack driveway mechanic yet), but that seems to make sense to me.
I'm not saying it doesn't do it at all, but it's not gonna do it while you're driving.
At idle the AF/R is controlled by readings from the O2 sensors. If they sense too much O2 the comp increases the injector pulse to richen it up. If the IAC was opening too much the idle would increase for one and secondly the CIL would come on.
