Shuddering
RaggedGT
Mod Dude
Jul 20, 2014
4,761
3,220
203
Taylorsville ky
A few of you guys know, over the last year or so I have been trying to put my 1994 GT back to driver status.
The main reason the car was parked for so long was a leaking Aode transmission with reverse issues got replaced with a used aode with only one forward gear.
The car is mostly stock-
•stock fuel pump
•stock injectors
•stock intake
•stock throttle body
•E303 cam-which it has had for several years
•typical headers-X pipe and two chambers
The car runs pig rich at times, randomly dies, surging idle at times, and slow to rev when warm.
I replaced and reran a lot of the vacuum lines,I haven’t found a leak anywhere. I have done the base idle reset, as well as replace the iac and throttle position sensor over the last year. Along with the temp sensor and a healthy cleaning of the maf.
I have been through @jrichker ’s checklist several times with not much change.
Where do I go from here guys? What would you suggest?
The other part to my extremely long line of questioning- the Aode transmission is a fresh rebuild ,less than 10 miles on it. New converter, fresh fluid at the correct level. Only things different are a Transgo shift kit and an aftermarket transmission cooler.
When driving the car,as long as I am leaning on it pretty good-the car pulls strong and up shifts like a champ. But under part throttle, light throttle-it will buck and shudder , almost to the point of bogging down and killing the engine and will only downshift under hard acceleration.
Am I having running issues and transmission issues-or do you think my poorly running engine is causing the transmission issues?
I’m lost guys-and a bit overwhelmed lol any ideas would be greatly appreciated
•stock fuel pump
•stock injectors
•stock intake
I'm saying you are having OD or LU issues on the trans..you should be in my car when I forget to disengage the locked up converter..
Reactions: RaggedGT
I can remember an issue with torque converter shudder on the mustang GTs and the Crown victorias. It would usually happen around 40 to 45mph. I've fixed several with a flu if d and filter change and the addition of Lucas transmission treatment.
That wasn't on bra d new transmissions or fresh rebuilds.
Reactions: RaggedGT
Alright guys,if I can have your ear again- I made some adjustments to the idle-to the Mlps-adjusted the shifter and fluid level.And I drove it further away from the house-that was a bit sketchy lol.
It drives better, but still has the shudder/bog at part throttle. But the car will not idle below 2K Rpms while in gear and I’d put money on that being my shudder/bog problems... At idle in park it hovers around 1K Rpms, and getting it to do that took forever(thanks @jrichker ) how do I set the idle for in gear/driving?
