Side-exit exhuast ideas?
  • Thread starter Thread starter streetstang67
  • Start date Start date May 26, 2005
1 of 2 Next Last
streetstang67
573
Lexington, SC
May 26, 2005
  • May 26, 2005
I'm looking for some ideas/pictures of side exhuast systems or anything besides the normal straight back duals. I thought about turn-downs, but I don't know if that would be too noisy; so the only other option I can think of is side exhuast, but I would want it to exit after the rear tire, not before (a.k.a. not like eleanor).
SitDown
335
Chicagoland
May 26, 2005
  • May 26, 2005
Ive seen a fox body that modified a buick grand national 'catback'. those exhaust kits exit to the side just behind the rear wheels. wasnt really my cup of tea, but looked clean
huRACEmentPSR
Banned
Apr 2, 2005
101
San Jose, CA
May 26, 2005
  • May 26, 2005
have a muffler shop custom make it. i saw an el camino today that had it right behind the rear tire
streetstang67
573
Lexington, SC
May 26, 2005
  • May 26, 2005
Does anybody have some pictures that I good go by?
L
LightningBug
21
Murfreesboro, TN
May 26, 2005
  • May 26, 2005
You could run it behind the rear wheels, but your exhaust would need to have some pretty big bends in it to clear the rear axle. I went with the more traditional approach:
Pathfinder65
142
Ottawa, Canada
May 26, 2005
  • May 26, 2005
What mufflers are you using with your set-up?
Dave
allcarfan
The Answer Man
2,458
North Atlanta
May 26, 2005
  • May 26, 2005
spintech makes the muffler you are looking for. The inlet and outlet are both on the front of the muffler. They also sell the curved exhaust pipes so they exit right in front of your rear wheels.
BobV
20+ Year Stangneter
May 18, 2003
474
Leavenworth, KS
May 26, 2005
  • May 26, 2005
Dynomax Super Turbo's work as well - part #17676 (2.5") or 17675 (2.25") - $49 ea at Summit.
I believe most of the major manufacturers have a front in/out muffler.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
May 26, 2005
  • May 26, 2005
There are really only two options I can think of. One is go the Shelby route and use long glasspacks and the other is use a chambered muffler with frontside in/out. Dynomax has a SuperTurbo muffler with the inlet/outlet on one end. I dont like this idea since the exhaust has to make almost two 180* turns, but alot of dyno tests have shown it doesnt hurt performance. The other sticker with me is you can see alot of the exhaust and it likely will not clear subframe connectors without oval tubing.
EDIT: BobV beat me to the SuperTurbos.
BobV
20+ Year Stangneter
May 18, 2003
474
Leavenworth, KS
May 26, 2005
#10
  • May 26, 2005
  • #10
If you look at the twists,turns and angles in a conventional muffler, making ONE 180* bend doesn't seem so bad...
In fact, Steeda got a HP gain with their Borla-based side-exit, compared to 3-chamber flows & tailpipes.
I've never had clearance issues with the side-exits - they don't hang down, and have never bottomed out. As far as SFC's, oval tubing works, as well as "thru-the-floor SFC's like the F-body guys use.
69 Capecod
97
Cape Cod MA.
May 26, 2005
#11
  • May 26, 2005
  • #11
Ok I love the Look But how loud is it I have single exaust glasback and I have to turn my raido up to hear it and forget ancwering a cell phone.
SitDown
335
Chicagoland
May 26, 2005
#12
  • May 26, 2005
  • #12
ur driving a vintage mustang, and looking into side exahaust...u may want to reconsider if your worried about hearing your cell phone.
fwiw, the dynomx super turbos r real quiet idling and crusing around until u step on it, then id get off the phone
BobV
20+ Year Stangneter
May 18, 2003
474
Leavenworth, KS
May 26, 2005
#13
  • May 26, 2005
  • #13
Good description - decent sound at idle, but does not keep you from carrying on normal conversation inside the car. QUIET at cruise speeds, more wind/road noise than exhaust...
But they ROAR when it's time to play.
Mine have been on 2+ years. I'm an "old guy" - 40+, and I didn't want anything loud & annoying. This setup is purrrrfect.
Check out the movie/sound clips at the bottom of this webpage (labeled "burnout videos").
66moneypit
536
Northern Va
May 26, 2005
#14
  • May 26, 2005
  • #14
Gotta ask who makes those wheels on your car lightningbug....very nice
streetstang67
573
Lexington, SC
May 26, 2005
#15
  • May 26, 2005
  • #15
Well I have flowmaster mufflers which are probably too far back for side exit in front of the rear tires, unless there are some serious bends invovled. Anybody done or seen side exhuast behind the rear tire?
Overall, the reason I want side exhaust is to stop the problem of exhuast fumes getting into the interior. It seems that many people with straight back exhuast also have this problem, and blame it on the aerodynamics of the car. I've heard that turn-downs or side exhaust will fix the problem. I'm afraid turn-downs would be too loud , but that seems like my best option right now; mabye I could put the turndowns real close to the trunk floor, farther from the ground. And I don't know how good side exhuast would look behind the rear tire?
iskwezm
4,159
20
79
Rowland Heights,California
May 26, 2005
#16
  • May 26, 2005
  • #16
turn downs will not get rid of the fumes comming in the car,it will make it worse.I have mine exiting in front of the tire with mandrle bends which is not what you want,but I really havent seen them exit after the tire to the side.
streetstang67
573
Lexington, SC
May 26, 2005
#17
  • May 26, 2005
  • #17
Turn-downs won't work? what else is left?
XXBULLETSXX
301
Kannapolis, NC
May 26, 2005
#18
  • May 26, 2005
  • #18
I sure would like to hear some ideas on this subject, because my car gets a LOT of exhaust inside the car. I too thought that if I put some side exit exhaust pipes in front of the rear tires that might fix my problem.
How is the exhaust in the car for those of you who have the side exit exhaust (in front of the rear tires)?
XXBULLETSXX
301
Kannapolis, NC
May 26, 2005
#19
  • May 26, 2005
  • #19
Oh and I forgot, What kind of tips are you guys using, round? Oval? Other?
Maybe a better picture of the exhaust tips would help.
Thanks guys!
D
DPMAZ
52
#20
  • May 26, 2005
  • #20
I just ordered the 65 Shelby style side exit aluminized exhaust from Tony D Branda, pipes, mufflers etc. for 149.00 should be here in a couple days, I'm going to add a crossover pipe I'll let you know how it works out /sounds..would have cost more than that to fabricate it yourself..
1 of 2 Next Last
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
