Okay so I just finished putting in my new ignition switch, because I thought that my signal lights weren't working because of it (I was wrong). The turning signals worked fine, then stopped working for a few days, then started working again, and now have stopped working completely. Does that sound like a bad flasher?
I've tried searching for the signal flasher, and for the life of me cannot find it. I've looked under the drivers dash, behind the radio, and under/behind the glove compartment. Does the signal flasher look the same as the hazard flasher in the fuse box, or different? What would be the easiest way to find the signal flasher? Like is there some wire I can start at and just follow it to the signal flasher? Thanks.
