Signals
  • Thread starter Thread starter lnhuff2000
  • Start date Start date Aug 9, 2008
L
lnhuff2000
  • Aug 9, 2008
What would cause signals not to work when everything else is working properly, lights, brakelights, running lights, flashers. I have replaced the flashers, all bulbs and the switch in the steering column seems to be working properly. Help!
iskwezm
4,159
20
79
Rowland Heights,California
Aug 9, 2008
  • Aug 9, 2008
Have you checked for power with the signals on and traced the wire back to see where it stops??? Power comming from the t/s switch and into the flasher???
xero0620
60
Vacaville Ca.
Aug 9, 2008
  • Aug 9, 2008
Is it the front signals, back signals, or both? I just got done chasing a wire problem similar to yours but my back brake lights didnt work and everything else did. It ended up being the switch in the steering column.
What year is your mustang?
What your going to have to do is test the wires for power going in to the steering column and test them coming out. Chances are its the steering column switch. The year of your mustang is need to help determine what color wires your chasing down.
L
lnhuff2000
  • Aug 10, 2008
Thanks for the replies. Update: I only had 8.5 volts going to the flasher. I am sure there is a weak connection somewhere but rather than trace it out, I put a jumper from a line that gave me 12v. Problem solved everything works great now. The flasher just wouldn't work with the lower 8.5 volts.
iskwezm
4,159
20
79
Aug 10, 2008
  • Aug 10, 2008
congrats
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
