Simptoms of a bad MAF sensor???help!
Jimmy26
277
Puerto Rico
Hey guys, what are the simptoms of a bad MAF sensor??
My car has a ck engine light (which I know is a sensor), is sound like when you have a fouled spark and I have to keep it above 1500 if not I will stall! :bang:
A bad MAF will cause the CEL to come on and sometimes will go out. Mine when it went bad would run crappy until it got up to temp and then was still choking the car at take off from a stop. Since the MAF tells the ECU how much air is coming in, the ECU was in turn sending incorrect fuel amounts to the injectors and was doing all sorts of crazy miss firing on different days. I drove around a long time like this until I found out the MAF was the culprit and am now scared to see what the inside of my cyliners look like.
Jarrod
