skipping and wont idle
jake1990gt
i just recently built a motor its a 306 with keithh black pistons e cam and trickflow heads and holley upper and lower intake 70mm throttle body but before i had stock heads on it and it ran fine but when i put the trick flow heads on now it wont idle and skips and pops i have replaced just about everything but injectors fuel pressure regulator and mass air please help its driving me nuts thanks
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
