I previously said I was going to do a full teardown and rebuild on my engine, however I'm begginning to second guess myself. At this point, I would like to just get it installed in my car and worry about all the power adders later. From what Stinger has said in the past you can pretty much just bolt these in from the donor car without doing anything, so that's the basis for the question of just leaving it alone.
As of this time, I have an assembled shortblock, all other parts on standby for install. Will the main/rod bearings and piston rings be allright as they are or should I replace them? I have no idea how many miles are on the engine, the factory crosshatching is still clearly visible, and the cylinder walls appear to be in perfect condition, so...what? Is there a way to check the piston rings without ripping apart the whole thing and creating even more work for myself or should I just go ahead and take it apart anyway?
My main concern is taking the whole thing apart and screwing up the install: improper torque settings, improper technique, etc. So what is the general consensus? Should I leave it alone and just re-assemble the engine and put it in, or should I get some tools and go ahead and rebuild the bottom end?
