  • SN95 4.6L Mustang Tech
SLICKS
  • Thread starter Thread starter louis mefford
  • Start date Start date May 21, 2009
L
louis mefford
22
  • May 21, 2009
hello, can anyone tell me what size slicks i should use i have a 1998 gt stock suspension i tried a 29x10.5x15, tire was way too tall, any help would be appreicated, thanks:SNSign:
98COBRA281
1,348
30
59
Port St. Lucie, Florida
May 21, 2009
  • May 21, 2009
26x10.5x15, thats about the same height as your average 245/45/17, or 275/40/17.....
L
louis mefford
22
  • May 21, 2009
thanks, thats what i thought, but wanted to check before i waste my money.....
Tim2002GT
635
Tulsa, Oklahoma
May 21, 2009
  • May 21, 2009
If your not making major hp/tq, you may be better off with the 26.0/8.5/15. Less rolling resistance. The 8.5's should hook well for most applications. If your making over 400rwhp, then I would go with the 10" or 10.5" wide. You will definately want to stay within 1" of your original tire height.
I make around 375rwhp/460ft-lbs. on the bottle and my car hooks pretty good with the 255/60/15 ET street radials. They are aprox. 27" tall and 8.5" wide. I have pulled a 1.71 60' with these tires. Before the year is over, I should be able to get into the 1.6x range. The reason I went with a 1" taller than stock size is to free up some rpm at the finish line. On my 315/35/17 Nitto dr's, I was crossing the line at almost 6200 rpm. Now I cross closer to 6000.
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
