  • 2005 - 2009 Specific Tech
Slightly Rough Idle
  • Thread starter Thread starter DMBuck
  • Start date Start date Aug 19, 2011
DMBuck
Macungie, PA
Aug 19, 2011
  • Aug 19, 2011
2009 GT. Only engine mods are a K&N CAI, Bassani Axel Back exhaust, just added Accel Super Coils 140033-8. Car starts right up, runs great at speed, no obvious miss or hesitation. When at the lower idle level shortly after the higher start-up idle, engine seems to idle ever so slightly rough. Somewhat intermittent, about every 10 seconds or so just a touch of roughness. Any ideas? Thanks,
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Aug 20, 2011
  • Aug 20, 2011
My guess would be the coils; the factory units have proven themselves to be better than aftermatket units.
DMBuck
Macungie, PA
Aug 20, 2011
  • Aug 20, 2011
Thanks. Only 6K miles on the car. Old coils back in similar low idle roughness. New coils back in, fresh tank of premium, bottle of Lucas. We'll see what happens. Ethanol causing this? Car is only a weekend driver...
jpplaw
185
Aug 22, 2011
  • Aug 22, 2011
Is the roughness something new? Or did it always do it? The stock cams are ground for torque, and are actually pretty darn good. However, they do not idle perfectly smooth even when there is nothing wrong. There is a very slight cam lope even when stock.
DMBuck
Macungie, PA
Aug 25, 2011
  • Aug 25, 2011
It's always had just a touch of roughness. No miss, nothing you notice at speed, just at low idle. I thought the new coils would eliminate. When you stare at the plenum, it looks pretty steady, then about every 10 to 15 seconds, you notice this slight wiggle/roughness. Does it with the stock and Accel coils.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
F
Spark Plugs Caused Rough Idle & Driving
  • firevert
  • Sep 1, 2025
2005 - 2009 Specific Tech Sep 3, 2025
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
