  • SN95 4.6L Mustang Tech
slipping cams
  • Thread starter Thread starter shinragt
  • Start date Start date Jun 8, 2009
shinragt
  • Jun 8, 2009
I have an 02 gt and last winter i had been driving the car all day with no problem let it sit for about an hour and then went to move it got in it to start it and it cranked over a few times then backfired and wouldnt start it just sputterd and backfired and die. after some checking i found that the drver side timing chain was streched out ,and the timing was off .The car only has 56k miles on it and the 14k i put on it since i got it havent been very hard on it a few races with friends . The timing i replaced both chains guides and tensioners and tried starting it again and it still would not run acted like it was out of time again. Looked a little deeper and found that the section were the cam gear is located had sliped the same problem the SHO has so im wondering if I should weld them up to fix that problem when i get the new cams and has anyone else heard or had this problem to and what might have caused it ?
J
jomull55
202
lucas, OH
Jun 9, 2009
  • Jun 9, 2009
if you tried to start the car with the timing off you may have bent valves in the head.
the only reason the cam gear should slip is if the bolt came loose which i have never heard of
which side is having the problem? did you touch the other side chain?
jeremy canter
402
Orange County , NY
Jun 9, 2009
  • Jun 9, 2009
pull the plugs do a compression test on the motor or/ and roll the motor over till each cylinder is at TDC then put air on it / this will check to see if you bent a valve > as for the cams just put new after market cams in it and forget it > newer P.I. cams 03/04 will fix your problem too if yoou want to do it on the cheap.
shinragt
  • Jun 10, 2009
yes i did try to start the engine with the timing off befor i found the stretched chain I replaced both chains and tensioners and guides with new and it still would not run right so i took the cams out and checked to see where the lobes were and found that the intake lobe on the #1 cyl had just closed at the point when the cylinder should be at tdc on the compresion stroke but I can not tell that untill the new cams i ordered have come in so i can compare them
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
SN95 4.6L Mustang Tech Nov 5, 2025
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
M
93 5.0 Microsquirt with Stage 3 trickflow tuning issues
  • marxpreston11
  • Jun 22, 2026
  • 2 3 4
2K
Qtrhrse23
