Slipping Clutch Experience???
  • Thread starter Thread starter Turkey Sammich
  • Start date Start date Nov 27, 2006
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Nov 27, 2006
  • Nov 27, 2006
I happened to be coming home from work when the enemy(ie ricer, in a Honduh Accord) pulled up next to me at a red light. He motions to me that he wants to race.
At which time while smoking him, I noticed that the engine sounds like it's revving when I accelerate, however it does it only in 4th & 5th gear. The RPM's will go up, however I will not be accelerating. Has anyone here, had these problems, how would one diagnose the issue and resolve per say issue?
Should an adjustment be done, or does it sound like the clutch needs to be completely replaced?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 27, 2006
  • Nov 27, 2006
where does your clutch engauge
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Nov 28, 2006
  • Nov 28, 2006
Ask ram360 to post the vid of me smoking my clutch instead of my tires. And my old car the clutch started to go i would romp on it in 5th and the rpms would shoot up but not accelerate..
sunil6784
620
Boston, MA
Nov 28, 2006
  • Nov 28, 2006
Sounds like you need a new clutch...
If it happens in only higher gears, thats a good sign that you need a new clutch.
ram360
2,162
Pennsylvania
Nov 28, 2006
  • Nov 28, 2006
Turkey Sammich
Jul 12, 2006
154
Nov 28, 2006
  • Nov 28, 2006
I'm thinking it will have to be replaced as well. I'm going to see about taking it in tomorrow to have it looked at.
Any idea's of what I should replace my current clutch with? (Other than one that doesn't slip?)
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Nov 28, 2006
  • Nov 28, 2006
cobra clutches are good (kc) They have really stock feel to em, and they last as well, centerforce units are good as well.
Turkey Sammich
Jul 12, 2006
154
Nov 28, 2006
  • Nov 28, 2006
I actually have a Centerforce clutch. However, it was installed by the prior owner and seeing the work he's done to the car, it was most likely used.
How difficult is it to install a new clutch? Is it a do-it yourself job or a little more advanced. And last but not least, how time consuming is this repair?
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Nov 28, 2006
  • Nov 28, 2006
well you can do it, its not that hard when the engine and tranny is out of the car, but your gonna have to jack it to the moon if you dont, drop the tranz, unbolt the pressure plate, you might have to have someone with a tourque wrench on the crank, to get em off, and, you will prolly get a gut feeling to resurface the flywheel, I say do it, although im not cuz im poor and lazy. you will need a clutch alignment tool also, which is like 3 bux, then you will see that the rear main seal is leaking which is no biggie, I mean your already under there, so you get a seal again like 3-4 bux, then put it all together, torque the bolts on the flywheel, blah blah, bolt up the tranz, go smoke some more f22- f23 vtec cars (accordz) That is like the shortest answer I have for ya.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
