  • SN95 4.6L Mustang Tech
slipping tranny????
  • Thread starter Thread starter PlatinumDevil
  • Start date Start date Apr 24, 2005
PlatinumDevil
Regina, Saskatchewan, Canada
Apr 24, 2005
  • Apr 24, 2005
Alright i recently aquired a 2000 GT auto with 46,000 miles (bonestock... i think)...
When put into drive it pauses for a second or two and then jerks the car (a little bit), when i pin it the shifts are slow and add a whiplash effect. Last night i noticed that when placed into drive it makes a high pitched meeeee noise before it jerks(yes i can't describe the sound so im using soundeffects).
How aggressive are the stock trannys? Could this be some sort of aftermarket thing? Is the tranny slipping? Am i low on fluid? Are there holes in the lines or something??? any help would be greatly appreciated.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 24, 2005
  • Apr 24, 2005
check the fluid level. to do it make sure the car is warm, running and on a level surface. with your foot on the brake pedal slowly cycle through the gears, all the way down to 1, staying in each gear for 5 seconds. then bring it back to park. check the dipstick with the trans in park. you might have to stab it a few times to make sure the level is correct. also check the condition of the fluid. it should have been changed already. if it smells really burnt, do nto change it, if you do the trans will have a good possibility of not working. if it jsut looks worn, go ahead and change it. here is an execellent writeup from crownvic.net on how to do the fluid, they use the same trans so almost everything is the same. http://www.crownvic.net/tech/transservice.htm
also you might want to consider switching to the FRPP pan M-7195-4R or the OEM pan F8UZ-7A194-AA. both increase capacity and have a drain plug.
PlatinumDevil
Apr 24, 2005
  • Apr 24, 2005
alright ill go out and check the fluid now, ill be back with results in 10
PlatinumDevil
Apr 24, 2005
  • Apr 24, 2005
so theres barely any in there and it is brown and smells burned... now what...
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 24, 2005
  • Apr 24, 2005
how burned does it smell? if it smells like a BBQ your tranny is probably toast.
PlatinumDevil
Apr 24, 2005
  • Apr 24, 2005
it smells like burned clutch/burning metal... not too too badly and its only slightly brown...
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 24, 2005
  • Apr 24, 2005
go ahead and try doing the fluid and filter. make sure you change out the filter. if you want to take it to a place to get a quicky flush done they wont do the filter. if you decided to do a flush, change out the filter first. you dont want the flushing action to push all the debris in the filter back into the trans.
also for fluid, make sure you use Mercon V ONLY. do NOT use a dexron3/Mercon with a modifier.
Y
YtnGT
202
TX
Apr 24, 2005
  • Apr 24, 2005
Change your trans fluid and filter. Then see how it does...
The 4r70w is a decent transmission.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 24, 2005
  • Apr 24, 2005
the 4r70w is an execellent trans, all that it asks in return is to be serviced. every person that ive talk to that had one blow eventually admitted to never servicing it. there were some random failures, but thats common with anything.
PlatinumDevil
Apr 24, 2005
#10
  • Apr 24, 2005
  • #10
alright thanks guys, i've had the car for 2 weeks now so dont blame me for not servicing it , when we bought it we checked everything, oil, brake fluid and they were all changed within 250miles, i forgot to check tranny fluid, cause i've never had to do that before...
I'll definately try the filter change + flush tomorrow, if that doesn't work, ill move to mexico and change my identity, since i can barely afford this car as it is.
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
G
HELP!! A4LD in 93 Mustang slips badly in reverse when warm
  • goofyfoot53
  • Apr 25, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Sep 10, 2024
89ripper
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
L
Engine 97 mustang gt manual weird idol when off the throttle and coasting in 3rd, 4th, or 5th
  • Lanezs
  • Jun 9, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
