Sluggish Problem & Backfire
  • Thread starter Thread starter cherrypony93
  • Start date Start date May 27, 2007
C
cherrypony93
49
  • May 27, 2007
I have a 88 GT. that is running sluggish between 2,000 - 3,000 rpm. She runs fine after that until I get on the highway and punch it then she gets real sluggish and the rpm needle go's crazy. Once in a while I will get backfire.
I just had an H-pipe installed with no cats. The installer hooked up the air pump until I can get a shorter belt. Would this air pump cause my problem.
Thanks,
Cherrypony93
back2fox
73
  • May 27, 2007
I removed all of my air pump stuff and didn't have any problems. Was it doing this before you removed the cats?
bloopbloob
578
Alberta
May 27, 2007
  • May 27, 2007
i have a similar problem i'm trying to get figured out. when i pull the codes i get 'egr not operating properly' and 'maf voltage low'. CEL comes on when rpms drop from about 3000 to 2000, and engine stumbles at these rms too. making me mad....! i thought it was the new location of the o2's with my longtubes, but im starting to think its a diff prob. because of the codes i pulled
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 27, 2007
  • May 27, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
C
cherrypony93
49
  • May 27, 2007
Back2fox, the car was running perfect until I changed the pipe. Is it possible the O2's went bad???
Cherrypony93
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
May 27, 2007
  • May 27, 2007
possibly...i had some hesitation problems and O2s fixed it right up!
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
A
Resolved 302 still running after turning off ignition
  • AlexM556
  • Saturday at 4:37 PM
Classic Mustang Specific Tech Sunday at 5:17 PM
AlexM556
A
