Sluggish take off
  • Thread starter Thread starter remohe
  • Start date Start date Sep 19, 2007
R
remohe
  • Sep 19, 2007
My 92 5.0 seems way to sluggish (especially on take off) for what I think it should be. At first I expected it with the AOD, but after a fews mods I still haven't picked up any. I put 4.10 gears and a shift kit in hoping to help the ol AOD. Besides that, the car is supercharged (vortech 5-6 lbs of boost), and a full exaust (BBK shorties, 2.5" H pipe- no cats, and Mac Turbos).
The car is only running 9.7-9.8 1/8 miles and my 60' hasn't improved from stock at 2.4-2.5. Stock I was still only getting 10.5's in the 1/8.
Am I just expecting more out of it than its giving? Possible something wrong?
Flavadave4
1,044
21
49
Utica, NY
Sep 19, 2007
  • Sep 19, 2007
Not to bust your balls......but those times are horrible for what you have, but you really need to work on the 60' times, a few tenths off your 60 foot can make big differnce on the other end. Do you spin out of the hole or does it hook and die? Give us a complete list of what you have on the car and whats been done.
ttop88
42
indiana
Sep 19, 2007
  • Sep 19, 2007
Sounds like you need suspension, Tires. and drivers education.
873Stang
221
riverside
Sep 19, 2007
  • Sep 19, 2007
wold at toque coverter and cam spec have any thing to do with his prob???
ttop88
42
indiana
Sep 20, 2007
  • Sep 20, 2007
With slicks and a converter he would drop at least a second in the quarter. Adding a converter without slicks may slow you down do to traction issues.
R
remohe
  • Sep 20, 2007
More Info
Hey Guys, thanks for replying.
Not busting my balls at all - I know I should be way quicker. I just don't know why i'm not.
I am running a stock converter. I try bumping the revs up at the line but the car won't hold past around 1500. Traction isn't an issue so much (any more). I invested in some BFG Radials this summer and havne't lost traction since.
I've unfortantly never taken that car down a 1/4 mile track. The one local is an 1/8 and thats the only place i've raced.
When I got the car it ran about a 10.8 1/8 mile. A little dissapointing, but figured for stock with 2:73's I could live with it. Put the exaust on (2.5 MAC H pipe, new MAC dual chambers) and changed the gears to 3:55. This got the car down to 10.3's. A year later took the factory manifolds off and replaced them with BBK Shorties. The car actually slowed back down to a 10.7. At first I thought I must have done something wrong putting the headers on - checked everything and they fit snug with no leaks. Next I thought I had better help out the AOD with a new shift kit and the 4:10's. I was able to pick up to a 10.6 but still had no clue why i slowed down in the first place.
Then I did something drastic - I was so disapointed with the car I decided to force some air in to it.
When I put the supercharger on the car wouldn't run the track with the street tires, so had to get the new drag radials. First full pass I got on the car only ran a 9.8. I was happy to finally get a single digit 1/8 mile, but at least a half second slower than i thought I could get. And 1st gear still has nothing. Through the entire process my 60' has changed from about a 2.6 now to a 2.4.
I'm still running everything else stock. Cam, heads, intake, ect. A couple weeks ago I tried putting a new PP 65mm TB and EGR on. Spent all day trying to adjust it so it wold stop stick wide open - eventually pulled it off and replaced it with the stock one. Works fine again.
Figuring it was just me knowing nothing about being a mechanic I let a couple of the Ford guys out at the strip try tuning it. As far as any of them could tell - it was tuned right where it should be.
Soooo - If anyone actually read through my long @ss story... Would a converter pick me up that much? Maybe theres something wrong somewhere?
ttop88
42
indiana
Sep 20, 2007
  • Sep 20, 2007
If there is something wrong it is the tranny! Could be the converter takin a crap.
FoxRod87
243
Carolina
Sep 21, 2007
  • Sep 21, 2007
Swap a 5 speed in and see what happens.
squeak93
2,352
418
164
Joplin, Missouri
Sep 21, 2007
  • Sep 21, 2007
If the tranny is stock and has never been touched, its wore out. Rebuild it, get a bigger stall while ur in there.
That will take care of ur line problems. You may want to do some good LCA's like HPM mega bit jrs or something equivilent.
Now for the motor. How many miles?
Might be time for a good hci. Then that thing will scream. Just don't get cheap on the supporting parts.
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
