Pulled into the garage tonight smelling electrical burning (not a great feeling). I traced the source to a rather heavy gauge wire that runs from the hot side of the starter solenoid into the harness that goes under the battery tray. This wire had what looks like a screw-together heavy fuse in it. It is seems to have done its job as it is now melted through. Downstream from this fuse, the wires split (Blk/Orange) and head into the harness and under the battery tray.
This all looks pretty factory (91 LX) with the exception of that fuse. Service manual shows several fusible links in this area but not an actual fuse. This is (was) a pretty big fuse, like the kind you see on big car stereo systems.
I checked to see if there was continuity to ground (a short) but didn't find anything there.
Any suggestions on what to do next?
Thanks!
Thanks!
