small tapping noise??
Kilgore Trout said:
You should check your spark plugs for tightness IMMEDIATELY... Do not over tighten though. Make sure that they are torqued to spec.
:stupid: if this don't fix it get back too us. there is also a TSB for valve guide noise.
but check those plugs many modular motors have blown plugs out with the threads. sometimes they loosen up first and make noise before they let go. all you can do is retourqe them down.
I think this may be what MikeZ28 is referring to:
03-16-04
Engine - 4.6L 2V-TICK NOISE FROM ENGINE-ENGINES BUILT BEFORE 8/29/2003
Some vehicles, equipped with the 4.6L 2V engine, with an "ENGINE BUILD DATE" prior to 8/29/03 may exhibit an engine tick noise that is present at all temperatures during idle. The noise may be emanating from the valve guide area in the Cylinder Head. The noise may not e heard with the hood open.
