Smog Delete
  • Thread starter Thread starter mustanglx91
  • Start date Start date Jan 2, 2008
mustanglx91
56
Wilkes-Barre PA
Jan 2, 2008
  • Jan 2, 2008
I am planing to add a cat less x pipe to my car. I wanted to delete the smog pump. I know I have to plug the back of the heads. But what else has to be done to make the car run right? What has to be done to the vacum lines? Also what belt size should I run? I heard a 84.5inch but wanted to be sure. Thanks
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Jan 3, 2008
  • Jan 3, 2008
yes 84.5" belt fits perfect, thats what size i tried out!
bloopbloob
578
Alberta
Jan 3, 2008
  • Jan 3, 2008
2 plugs on the back of the heads, a shorter belt, remove all the plumbing, and cap or weld your crossover pipe. thats about it. are you taking it off or just bypassing the pump?
mustanglx91
56
Wilkes-Barre PA
Jan 3, 2008
  • Jan 3, 2008
I would to take the pump off.
mustanglx91
56
Wilkes-Barre PA
Jan 3, 2008
  • Jan 3, 2008
What about the vaccum lines on the smog control?
bloopbloob
578
Alberta
Jan 3, 2008
  • Jan 3, 2008
oh, right! there is 1 vacuum line iirc that i plugged...
ninety15.0
1,336
  • Jan 3, 2008
You will have a KAM error code...IIRC it will be 81. There is some sort of resistor fix/hack job you can do to eliminate that code. Should have no ill effects on the car though.
ryan218
Dec 28, 2005
columbus ohio
Jan 3, 2008
  • Jan 3, 2008
what dose IIRC mean?
if i recall correctly?
ttop88
42
indiana
Jan 3, 2008
  • Jan 3, 2008
Remember, but
Yup, good enough
mustanglx91
56
Wilkes-Barre PA
Jan 3, 2008
#10
  • Jan 3, 2008
  • #10
Will this affect how the car runs? I read that they sometimes run rich after deleting the pump and cats.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jan 4, 2008
#11
  • Jan 4, 2008
  • #11
you shouldnt notice any difference in how the car drives. the exhaust may have a gassy/exhaust gas smell to it that it didnt have before. this is a result of the smog and cats being gone, the crap in the exhaust isnt getting burned up from the smog pump. so it goes out the tail pipe and may smell. but the engine should run the same ...
a little trick for plugging the back of the heads.
take the air injecton tube out and CUT the little heads off ( that bolt to the head) and flip them around and bolt them back in place. it will cover the hole. its a hillbilly fix but it works lol
mustanglx91
56
Wilkes-Barre PA
Jan 4, 2008
#12
  • Jan 4, 2008
  • #12
Thanks for all your help. If anybody else has anything to say about it, please do.
bloopbloob
578
Alberta
Jan 4, 2008
#13
  • Jan 4, 2008
  • #13
that is one option, you can also use a broken off spark plug to plug the hole, or the bolt size is 5/8", 11 threads per inch, and about 1" long.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Jan 5, 2008
#14
  • Jan 5, 2008
  • #14
yes the sparkplug thing works great!!!
85hatchgt
Pelham, Alabama
Jan 6, 2008
#15
  • Jan 6, 2008
  • #15
uhhh maybe im an odd one but i had to use a 76 inch belt to fit mine with stock pullies and all after deleting the smog pump
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Jan 6, 2008
#16
  • Jan 6, 2008
  • #16
you got a/c?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 6, 2008
#17
  • Jan 6, 2008
  • #17
TAB & TAD solenoid valve eliminators – eliminate codes 81 & 82 and 44 & 94
Don’t do this if you have a catalytic converter H pipe. The catalytic converters must have the air from the smog pump or they will clog up and choke.
See www.Newark.com for the resistors to replace the TAB & TAD solenoids
http://www.newark.com/jsp/Passives/Wirewound/OHMITE/43F82RE/displayProduct.jsp?sku=64K8974
If the link fails do a search using the park number
82 ohm, 3 watt wirewound resistor, 94 cents each.
Newark P/N 64K8974
Ohmite part # 43F82RE.
Pay a visit to your local Radio Shack to get some heat shrink and some crimp on tap terminals. They do not stock the resistors. Or you can use the Ford connector pin kit from AutoZone.
18 gauge crimp on taps Catalog #: 64-3053
Put the resistor inside the heat shrink tubing and crimp the connectors on. I would choose the Ford pin connectors since they should plug in the TAD wiring. That way you haven't modified the wiring so it is easy to re-install the TAD solenoids if emissions testing comes to your area.
Two flat pin connectors.
One 82 ohm, 3 watt resistor.
One piece 3/8" heat sink tubing 2" long.
Two pieces 3/16" heat shrink tubing 1 1/2" long.
Solder the pins onto the resistor leads using electrical solder.
Slide the 3/8" heat shrink tubing over the resistor.
Slide the two pieces of 3/16" heat shrink tubing over the two wires, leaving the flat part of the pins uncovered.
It helps to have the resistor leads straight and not bent as shown in the first picture when you apply heat to the heat shrink tubing. That way, the tubing shrinks more evenly.
Finally, apply heat to shrink all the tubing uniformly.
Bend the leads to fit the spacing on the female TAB & TAD connector sockets.
Push the connector pins of the completed resistor assembly into the empty female TAD or TAD connector sockets on the wiring harness. The resistor assemblies replace the missing solenoids: one resistor assembly per solenoid socket.
Do not crimp on the pins and wrap the mess with electrical tape and say you got the idea from me. If you do, and I hear of it, I will say unkind things about your intelligence and family heritage. Do Quality Work!
This information is for informational purposes only and is intended for use only on off road vehicles. It should not be used on any vehicle operated on public roads.
Operating a vehicle modified in such a manner on public roads is a violation of the EPA codes regarding modification of emission controlled vehicles.
mustanglx91
56
Wilkes-Barre PA
Jan 7, 2008
#18
  • Jan 7, 2008
  • #18
Thanks, thats a big help !!!
scld1354
41
#19
  • Jan 27, 2008
  • #19
Hi guys. I am going to be doing this also, and I have two questions. Where did you get the flat pin connectors? What was the purpose of the crimp on tap terminals and the ford connector pin kit?
Thanks
Jon
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
Smog delete /vacuum lines
  • Serg.Xof
  • Feb 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 18, 2026
RileyDymond
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 9:34 PM
Qtrhrse23
