R RycheGT Member May 31, 2005 73 0 6 Thomasville, NC Aug 2, 2008 #1 Aug 2, 2008 #1 now that my o/r x is on its time to remove the smog pump etc. Any tips for ease of removing everything. What to plug, pull out, etc.
Y YELLOW 94 Founding Member Nov 19, 1999 428 0 17 Rio Rancho NM Aug 2, 2008 #2 Aug 2, 2008 #2 Plug holes behind the heads, the exhaust on the mid pipe, vacuum ports. It pretty simple to do. You can get a smog pump delete pully or try a smaller belt. I used the delete pully. Good luck. later Orlie
hollywoodstang Active Member May 23, 2006 1,095 2 36 Aug 2, 2008 #3 Aug 2, 2008 #3 I was thinking about doing this...I said forget it. But it is easy to remove them. there is thread on here i started so look for it in SEARCH
