Smog Diverter Needed?
  • Thread starter Thread starter Mick Bellar
  • Start date Start date Jun 20, 2014
Mick Bellar
  • Jun 20, 2014
The 1992 Mustang I purchased was from a county that didn't require smog testing, and was missing many smog parts. I am replacing the smog pump, adding cats to the h-pipe and am hoping someone can help with the diverter valve. My heads aren't ported for the smog pipe. Can I just run the bypass valve straight to the check valve for the converter pipe and eliminate the diverter valve? EPA here just wants to see a smog pump and converters and a passing emissions level. Any help greatly appreciated.
Mick Bellar
  • Jun 20, 2014
I am not looking to buy parts here, I am looking for information about the diverter valve on a 1992 Mustang Gt. If I bypass the diverter valve because my heads don't have the smog provision can I run directly from the bypass valve to the converter tube or will that not allow my converters not to reach proper temperature?
jcgafford
1,114
95
104
Adrian, MI
Jun 20, 2014
  • Jun 20, 2014
The oem tubing could just dump to the atmosphere. Do you have all the parts?
Mustang5L5
Mod Dude
Feb 18, 2001
43,345
18,074
224
Massachusetts
Jun 21, 2014
  • Jun 21, 2014
Yes. You can do that
Mick Bellar
  • Jun 29, 2014
Thanks for the help. I am gathering the parts slowly. I have a dyno shop who is going to give me a good tune, then directly to the e-check station. I will keep you posted.
Mustang5L5
Mod Dude
Feb 18, 2001
43,345
18,074
224
Massachusetts
Jun 30, 2014
  • Jun 30, 2014
Basically the diverter only dumps air into the cylinder heads to feed the precats during warmpup. After the engine is warmed up, the directer changes to the main cats.
By just having the line run directly, you lose the warm-up air to the heads to feed the precats, but who cares as long as you go get the car inspected when it's hot as it would be using the main cats anyway
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
I
Engine What Aluminum Heads???
  • Iceman1998
  • Sep 8, 2024
2K
Fox 5.0 Mustang Tech Sep 15, 2024
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
