Smog Pump delete problems
91stangy
116
Anyone have any issues with the pulleys not lining up after the install of the ksr billet smog pump delete, it ate a rib off my belt yesterday. Sorry if there is already an answer to this as im at work and need to find the answer today and cant look at the moment. Thanks in advance.
take that delete kit off and just run a shorter belt, those kits are usually made with cheap bearings and will be junk in under 10k miles.
The hardest part will be finding a correct belt size, my advice would be to go to the parts store with the car and find the correct size belt there, i always measure the belt size i need, and i rarely get it right on the first shot
How would that work on a vortech application, i think there has to be something there in order to be tensioned at all. I already had issues finding the correct belt size to fit on the current setup for some unknown reason.
With a vortech blower you need the smog pulley in place as the belt is required to run that way.
I couldn't tell you which is the best delete to run however. I removed my pump and just rerouted the belt. No delete pulley needed for me since i'm N/A.
BTW, this is how you'd reroute the belt if you were N/A so you wouldnt need a pulley
Yeah definitely didnt think it was possible to run no smog pulley with a vortech, so i guess my question still applies... Does anyone know how to space this pulley out so it lines up correctly and doesnt eat anymore belts?
bearing life will suffer by smog pump removal/bypass with shorter belt!
One important factor that people don't consider when bypassing their smog pump is that water pump and alternator bearings will go out quicker! The reason is that the more pulleys you have the longer your bearings will last (a stock 5.0 has seven pulleys/bearings. The more pulleys you have, the more the radial loading is reduced on each individual pulley. This fact is just simple automotive engineering! If you want your water pump and alternator bearings to last when you remove your smog pump, install a smog pump delete idler pulley! The company I work with manufactures a P/S and A/C delete kit for 5.0 engines that utilizes a idler pulley that mounts in the P/S bracket. They seem to do an excellent job.
I don't agree. All cars built before serpentine belts came on the scene had only one accessory per belt and they didn't have any problem with premature bearing failure. Besides, the only force each accessory sees is the amount of tension from the tensioner. Removing an accessory won't magically cause the others to have more lateral force applied to them. Simple automotive engineering... no... just simple physics.
I disagree. Belt wrap isn't going to do much to change the amount of load on each pulley. Plenty of vehicles run multiple belts with less pulleys than the 5.0 runs with the smog and a/c deleted. Some run crank + accessory only...even today. I've had my smog pump and a/c gone for 8 years...still running the same alt and WP as i had before then. If your tensioner is in proper working condition, shouldn't be a prob considering it's 1 less pulley than a non-A/C 5.0 would have normally.
radial bearing loading is different when in dynamic state
An NTN bearing engineer who's company makes pulley bearings for the automotive industry has told me......
1. when an engine is in static state (not running) the bearing radial load is distributed evenly over the seven pulleys! This load is determined by the belt tensioner pressure applied to the serpentine belt.
2. when in a dynamic or "running state" there is suddenly a pulling side and a slack side to the drive pulley (harmonic balancer). What actually happens is that the individual load on each pulley is now shifted somewhat (no longer evenly distributed as in static state). The P/S and A/C pulleys because they are immediately on the pulling side of the drive pulley (harmonic balancer), will now have a greater loading than when they were in a static state! The pulleys close to the slack side such as W/P and S/P will have less of a loading when in dynamic state! This fact is why you should keep your W/P pulley on the slack side of the drive pulley (as the factory belt routing dictates). I have seen belt routing with W/P pulley immediately on pull side of drive pulley which puts greater radial loading on W/P bearings (especially at high RPMs). By installing a S/P delete pulley you can keep W/P pulley immediately on slack side of drive pulley and W/P bearings will last longer!!! key buzz words are..... "bearing radial load shifing when going from static to dynamic state"!
This was definitely an interesting read..Thank you.
I know is an older thread, but nevertheless.
