Smog Pump Exhaust Line
  • Thread starter Thread starter splogan
  • Start date Start date May 2, 2015
splogan
127
  • May 2, 2015
I have just about had it fighting with the steel pipe going to the h pipe. What effect will not hooking it up have if i plug the hole in the actual h pipe ?
Benboi92GT
101
May 3, 2015
  • May 3, 2015
Possible premature failure of your catalytic convertors?
splogan
127
  • May 3, 2015
The cats are gone. I am installing a BBK H pipe
Benboi92GT
101
May 3, 2015
  • May 3, 2015
Glad I can spell correctly, read "converter" lol. It shouldn't affect a thing then. Is your crossover tube still in place on the back of the cylinder heads?
splogan
127
  • May 3, 2015
Everything is still in place except that damn pipe that wont snake back into position.
Benboi92GT
101
May 3, 2015
  • May 3, 2015
If you are having trouble getting the tube to reach, I would suggest this part:
List: Catalytic Converter Air Tube - 1984 Ford F-150 | O'Reilly Auto Parts
Without turning off the thermactor air function in the computer, I am unsure if you would run in to problems capping it off or not.
Pay no mind to the "1984 Ford F-150" part of that link. It is a universal part.
splogan
127
  • May 3, 2015
Is that just a flexible rubber tube to take the place of the rigid steel one
Benboi92GT
101
May 3, 2015
  • May 3, 2015
Correct, you will cut the rubber tube in half, and put the steel tube (with clamps) in between the two halves of rubber allowing you to bridge the gap between the new H-pipe and the pipe coming from the air pump.
I assume that's what your problem is, correct? The new H-pipe changed the orientation of your smog equipment?
splogan
127
  • May 3, 2015
It reaches but somehow it came misaligned while installing the transmission and H pipe and it will be a cold day in hell before all that comes out again to align that thing
Benboi92GT
101
May 3, 2015
#10
  • May 3, 2015
  • #10
I would order that part, and use it.
Or you can cap it off, but like I said, I am unsure of how it will work with the thermactor air function still active in your EEC. I'd question where the air goes when the computer is telling the diverter valve to pump air into your cats.
If you decide to use the Walker part, I'd cut some off of the original tubing, allowing you to route it how you want.
J
4 bank eliminator chip
  • JJ's90fox
  • Feb 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
AeroCoupe
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
C
Exhaust 4 Cats required for smog in California?
  • Codosuarus
  • Sep 28, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
Scottyding73
