smog pump...fitment.
anybody know? i thought i read somewhere that it would work if you switched the pulleys putting the 92 pulley on the 95 smog pump,and the 95 has a, L outlet where the 93 and later have a straight outlet....can anyone verify...thanks
Bill, my 94 eats smog pumps like crazy so I looked into putting a fox pump on the 94. As you said, the output-nozzle location is different but I dont see why the SN pump location wouldnt work (it was moved to the rear for the ABS module on SN's). I never got to check clocking and bolt hole arrangments though.
I'm thinkin of getting a new fox pump and tryin it on the 94 (cant find new SN pumps).
Justin my friend. Yep. I tore it apart for analysis and the number 3 bearing that goes around the mainshaft had seized, which scored the mainshaft beyond repair (when I opened the backing plate, chunks of needle bearings poured out). :(
It sucked because otherwise the pump was really smooth - the bushings that guide the vanes were in really good shape which is why it was so free-turning. Normally those bushings get sloppy which allows the vanes to load up and drag along the walls.
Thank you again for giving it to me though - it performed wonderfully before that!
