  • 1994 - 1995 Specific Tech
smog pump hose removal
  • Thread starter Thread starter dbiser
  • Start date Start date Dec 12, 2007
dbiser
24
wv
Dec 12, 2007
  • Dec 12, 2007
i have a 95 gt i have removed the smog pump and added the delete kit i want to remove the hose that runs back along the block and the turns in to the hard line it looks like bolts on does it? if i remove it will i need a plate or something to cover it.
thanks dustin
Stanger007
2,015
Baton Rouge, LA
Dec 12, 2007
  • Dec 12, 2007
You've got a couple options.
Option 1: Leave the hardline and get a vacuum cap from the auto parts store and cap it off. (This worked for a long time for me until I got around to pulling off the hard lines -- next option)
Option 2: Remove the pipe in the back of the head (one bolt per head) and then cut the pipes, and flip them over to seal up the holes.
I can take pictures for you of exactly how I did it on my E7's now that they are off the car, holler if you want a set.
Wes
steede302
75
jacksonville fl
Dec 12, 2007
  • Dec 12, 2007
I think ford sells thermactor plugs for that or just cut them and flip them over and use rtv sealent. worked for so far.
Bosko5.0
1,067
longwood, FL
Dec 12, 2007
  • Dec 12, 2007
spark plugs work TOO!
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Thursday at 4:16 PM
DadLife0724
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
T
Engine Broken Smog pump bolt
  • townethug
  • Jun 14, 2025
Fox 5.0 Mustang Tech Jun 16, 2025
limp
