smog pump question
  • Thread starter Thread starter willys1
  • Start date Start date Feb 7, 2006
1 of 2 Next Last
willys1
1,004
New Jersey
Feb 7, 2006
  • Feb 7, 2006
I just got an X-pipe on and it didnt have a connector for the smog pump hose so its just hanging pumping out air..Will this hurt it at all?
95GTV8
386
Washington State
Feb 7, 2006
  • Feb 7, 2006
shouldn't when i got my o/r h pipe, i am gonna take out my smog pump
HISSIN50
34
129
Feb 7, 2006
  • Feb 7, 2006
Agreed - it should be alright.
5.0 Nostalgia
904
CT
Feb 7, 2006
  • Feb 7, 2006
Do you mean you took the hose off and it's just pumping air into the engine bay or the hose is hanging? Either way the only problem will be that you will hear some noise when you rev up the engine. If you still have the hose connected, I would take it off so it doesn't hang down and get caught on something.
HISSIN50
34
129
Feb 8, 2006
  • Feb 8, 2006
That is a good point by 5.0Nos. Not having run with the line disco'd, I figured the TAB/TAD would muffle noise. If removing the hose at the pump, I think I would rig up a funky filter to keep debris and try and keep moisture out of the pump, since that will wipe it out fast (I have been in an AIR pump saga with the '94).
willys1
1,004
New Jersey
Feb 8, 2006
  • Feb 8, 2006
Its still underneath the car,but out of the way.Yeah,you can hear it,sounds like an exhaust leak..The check engine lite comes on for a few seconds while its still cold.But goes away when its warmed up.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Feb 8, 2006
  • Feb 8, 2006
Just rip that smog stuff out of there. Don't need it if you got no cats.
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Feb 8, 2006
  • Feb 8, 2006
Second the ripping out of the smog pump "plumbing". Just get a shorter belt and bypass the smog pump and disconnect all the vacuum hoses, plugging what needs to be, then take the smog pump out. Is about a 10 minute job including jacking up and down the car. Plus a tiny weight reduction
willys1
1,004
New Jersey
Feb 8, 2006
  • Feb 8, 2006
Nope!! Too me its all about having a 100% stock vehicle with everything working!! Plus having a smog pump will help at inspection time!! The fact that Im shooting for low to mid 13's makes having a stock looking 5.0 worth the while
and I have cats!!
willys1
1,004
New Jersey
Feb 8, 2006
#10
  • Feb 8, 2006
  • #10
Actually my exhuast guy said he can make me a custom set up so I can hook the hose up.I think Im gonna!!
5.0 Nostalgia
904
CT
Feb 8, 2006
#11
  • Feb 8, 2006
  • #11
What kind of exhaust pipe are you using?
willys1
1,004
New Jersey
Feb 8, 2006
#12
  • Feb 8, 2006
  • #12
VFS catted X
5.0 Nostalgia
904
CT
Feb 8, 2006
#13
  • Feb 8, 2006
  • #13
Don't know too much about that one. But...
You can have a muffler shop drill a hole in the pipe and weld a tube to the side to connect your smog tube. You will probably have to cut your smog tube and then use silicone hose to connect it to you pipe.
willys1
1,004
New Jersey
Feb 9, 2006
#14
  • Feb 9, 2006
  • #14
Yeah Im gonna get it done.
wht93gtEd
29
Jersey Shore, New Jersey
Feb 9, 2006
#15
  • Feb 9, 2006
  • #15
if you have cats without the smog pump hooked up, won't the cats get clogged?
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Feb 9, 2006
#16
  • Feb 9, 2006
  • #16
Yep. So wyllis1, you might not want to drive the car ..... except maybe to the place you're going to get the pipe tapped.
willys1
1,004
New Jersey
Feb 9, 2006
#17
  • Feb 9, 2006
  • #17
no they wont.Its mainly for when the car first starts up!!
And to prove it the factory H pipe has 4 cats,only 2 of them are connected to the smog pump!!
HISSIN50
34
129
Feb 9, 2006
#18
  • Feb 9, 2006
  • #18
The first two cats are referred to as Pre-cats.
The air injection from the A.I.R. pump does help keep the cats going, as well as in the catalyzation process (air doesnt magically appear in there).
Now I will say that I have yet to find definitive info about aftermarket cats. It seems to me that some are made more for oxygen depleted environments and might be less likely to deteriorate and/or allow full catalyzation.
Willys, I am not sure about your last comment. For those who are confused, the AIR pump flow is directed at the back of the heads to help light off the cats when the motor is cold. So if one is going to delete a flowpath, the one to the heads is the one to delete. I know you know that - I am just confused about the order of comments on this thread.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Feb 9, 2006
#19
  • Feb 9, 2006
  • #19
I wasn't speaking from personal experience there .... I just gathered that information from other forum members (who said their catalytic converters clogged after removing the smog pump).
JT, you seem to have a good amount of experience with the smog stuff, lol. What's your take on this?
willys1
1,004
New Jersey
Feb 9, 2006
#20
  • Feb 9, 2006
  • #20
theres nothing disconnected.The smog pump is pumping air through the hose still.My exhaust guy has the set up for the hose to the cats from a y pipe and says it will work.He just has to do some drilling and welding. They are magnaflow cats,they are a good cats.If there was a clogging problem if no smog pump was present,then they would have made hook ups for the cats!! No?
1 of 2 Next Last
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
