smog system delete
  • Thread starter Thread starter Modular2v
  • Start date Start date Nov 26, 2007
Modular2v
3,222
23
99
oklahoma
Nov 26, 2007
  • Nov 26, 2007
Just got through doing a 4cyl to 5.0 conversion and was wondering what all i need to do to get the car to run right without ANY smog junk!
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Nov 26, 2007
  • Nov 26, 2007
Custom tune for one.
The engine will run fine. Not like the smog junk robs any HP. It just will run a little dirty and if you delete the EGR, a custom tune is mandatory.
You'll also get check engine codes for the missing components
Modular2v
3,222
23
99
oklahoma
Nov 26, 2007
  • Nov 26, 2007
so the car is going to run fine just not optimum?
bloopbloob
578
Alberta
Nov 26, 2007
  • Nov 26, 2007
the egr is not part of the smog system. your car will run just fine without a smog pump(as long as you remove your converters, or get an off road crossover pipe). this won't cause a CEL either. deleting the egr stuff is not a good idea unless you get a custom tune.
to delete the smog system, all you have to do is remove the pump and brackets, and tubing, plug the hole in your crossover pipe where the tubing enters, and remove the tubing that runs from the back of your heads into the smog pump. you can plug the holes in the heads with a 5/8 bolt, 11tpi, about 1 inch long, or a broken off spark plug. you will also have to buy a new serp. belt.
Modular2v
3,222
23
99
oklahoma
Nov 26, 2007
  • Nov 26, 2007
LOL this is exactly what i did! I plan on keeping the EGR! Car has no converters.
bloopbloob
578
Alberta
Nov 26, 2007
  • Nov 26, 2007
Modular2v said:
[/B]
what did you do? i'm not following you here.... did you already remove everything?? your original post was only an hour ago!
Modular2v
3,222
23
99
oklahoma
Nov 26, 2007
  • Nov 26, 2007
I had already done everything u listed! I was just wondering if i could get by with it without a tune! I havent started the car yet.....still waiting on the starter!
F
Fox8950
247
Nov 26, 2007
  • Nov 26, 2007
I wouldn't worry about a tune especially if you do it correct and don't have any CEL pop up on ya. I deleted all my smog stuff AND have my EGR deleted as well with no custom tune and don't run into any issues.
ShortThrow50
923
Pa
Nov 26, 2007
  • Nov 26, 2007
first I ever heard of needin a tune after a smog delete
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 26, 2007
#10
  • Nov 26, 2007
  • #10
TAB & TAD solenoid valve eliminators – eliminate codes 81 & 82 and 44 & 94
Don’t do this if you have a catalytic converter H pipe. The catalytic converters must have the air from the smog pump or they will clog up and choke.
See www.Newark.com for the resistors to replace the TAB & TAD solenoids
http://www.newark.com/jsp/Passives/Wirewound/OHMITE/43F82RE/displayProduct.jsp?sku=64K8974
If the link fails do a search using the park number
82 ohm, 3 watt wirewound resistor, 94 cents each.
Newark P/N 64K8974
Ohmite part # 43F82RE.
Pay a visit to your local Radio Shack to get some heat shrink and some crimp on tap terminals. They do not stock the resistors. Or you can use the Ford connector pin kit from AutoZone.
18 gauge crimp on taps Catalog #: 64-3053
Put the resistor inside the heat shrink tubing and crimp the connectors on. I would choose the Ford pin connectors since they should plug in the TAD wiring. That way you haven't modified the wiring so it is easy to re-install the TAD solenoids if emissions testing comes to your area.
Two flat pin connectors.
One 82 ohm, 3 watt resistor.
One piece 3/8" heat sink tubing 2" long.
Two pieces 3/16" heat shrink tubing 1 1/2" long.
Solder the pins onto the resistor leads using electrical solder.
Slide the 3/8" heat shrink tubing over the resistor.
Slide the two pieces of 3/16" heat shrink tubing over the two wires, leaving the flat part of the pins uncovered.
It helps to have the resistor leads straight and not bent as shown in the first picture when you apply heat to the heat shrink tubing. That way, the tubing shrinks more evenly.
Finally, apply heat to shrink all the tubing uniformly.
Bend the leads to fit the spacing on the female TAB & TAD connector sockets.
Push the connector pins of the completed resistor assembly into the empty female TAD or TAD connector sockets on the wiring harness. The resistor assemblies replace the missing solenoids: one resistor assembly per solenoid socket.
Do not crimp on the pins and wrap the mess with electrical tape and say you got the idea from me. If you do, and I hear of it, I will say unkind things about your intelligence and family heritage. Do Quality Work!
This information is for informational purposes only and is intended for use only on off road vehicles. It should not be used on any vehicle operated on public roads.
Operating a vehicle modified in such a manner on public roads is a violation of the EPA codes regarding modification of emission controlled vehicles.
Modular2v
3,222
23
99
oklahoma
Nov 28, 2007
#11
  • Nov 28, 2007
  • #11
one more question...... Do i need the MAP sensor out of the donor car or will the 4 cylinder map sensor work?
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Grown Man Crying
  • Potomus Pete
  • Sep 8, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
LILCBRA
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
C
Exhaust 4 Cats required for smog in California?
  • Codosuarus
  • Sep 28, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
Scottyding73
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
