smoke HELP!!!
blue smoke is oil.. valve seals, piston rings, etc.
white smoke is coolant.. typically seen on blown head gaskets.
black is burnt gas, mostly when the car is running rich, or like crap.
Blue smoke = oil. Usually getting into combustion chamber through bad valve stem seals/worn valve guides/worn piston rings.
Black smoke = rich mixture/excess fuel.
White/grey smoke = water/antifreeze entering combustion chamber through cracked block/cracked heads/bad head gasket etc. If you are running an automatic trans that uses a vacuum modulator like a C4, C6 trans fluid can get into the combustion chamber through a bad vacuum modulator and cause white/grey smoke as well.
