So I have a smoke on startup and hard acceleration problem. I'm almost certain the problem is in the heads, ie valve stem seals or valve guides. I say this because the bottom end was just rebuilt. I put a set of heads on that I thought was in good condition, but apparently they were not.
I'm hoping the problem is just the valve stem seals, and that I can change them with the heads on the car. I know tools are available to do this, but I wanted to know if any of you have done it before? Is it a huge hassle or is it relatively easy to do. I know I'll have to remove the upper intake and valve covers, that's no big deal. I also know I'll need an air compressor which I have. I'm wondering how well the tools work and if the air compressor will reliably keep the valves from falling in the cylinders. Also where would you get the tools, and are they expensive?
