Smoking Instrument Panel
maximos
188
Columbus, OH
The other day I pulled my headlight knob and a burning smell filled my car. At the time I assumed the smell was outside but then I realized that my instrument panel lights were not coming on. I just checked the fuse and it was blown and I replaced it. I pulled the knob again after replacing the fuse and white smoke began to come out of the left side of the dash (the instrument panel light still didn't work). Any ideas? Thanks.
It's the headlight switch, common problem unfortunately! We had one in the shop last week with the same problem.
Take off the bezel around the gauge cluster (two torx screws above the speedo and pull the headlight switch off) and you can get to the switch.
Check to see if the switch and/or connector is burnt.
The connector is here: 94-04 CONNECTOR, HEADLIGHT SWITCH MUSTANG
You can get the switch locally at the parts store.
Wes
Looks like I was wrong - Latemodel Restoration only has the connector, not the switch. You may want to order the connector because yours is likely melted somewhat. I couldn't tell you which of the parts at Advance Auto Parts is the right one, the photos both look different than our switch. :shrug:
same thing happened to me but without the smoke. i'll be getting a new sw on sat. good ol ford keeping me on my toes. i was lucky enough to be able to whak the dash to get it to come back on BTW: THE DASH LIGHTS AND TAIL LIGHTS ARE ON THE SAME CIRCUIT
In case it helps someone:
I recently swapped my headlight switch and connector. As far as locally available parts, I use Standard Brand when I can. I like their stuff. The parts man and I had to dig a bit as the connector listed didnt work. We found a Standard Brand S-607 seemed to work. It was listed for Ford Trucks.
