smoking problem..
  • Thread starter Thread starter ShAkE N BaKe!!
  • Start date Start date Apr 26, 2007
First Prev 2 of 2
R
RUSTYNUT
128
PDX
Apr 27, 2007
#21
  • Apr 27, 2007
  • #21
I had an old truck that was having troubles passing DEQ. Tried Restore and passed with flying colors. It uses powdered lead, copper and silver insead of just thickening up your oil. Fills in the scratches in bearings cylinder walls etc. You might try going to heavier oil also. The only bad side effect after running that f150 another 100,000.00 miles I finaly had the engine rebuilt and the lead ruined the solution in the hot tank.
H
headgrinder
33
san rafael ca.
Apr 27, 2007
#22
  • Apr 27, 2007
  • #22
smoke problem
Find a repair shop that caries BG products and get a can of Quick Clean. It is a mild solvent put it in oil and idle for 15 - 30 min do not rev engine.It can clean the oil rings and may slow oil burning I have seen it stop it completly and also do nothing.
It should cost $10-15 better than an overhaul. Good luck Ps change oil after
F
FLStang
58
Central FL
Apr 28, 2007
#23
  • Apr 28, 2007
  • #23
Do a compression test to determine/rule out possible piston ring failure.
If it burns oil, there's generally only three ways for oil to get into the combustion chamber:
Worn or broken piston rings, or damaged pistons (Ring lands)
Worn valve stem seals
Leaking head gasket
The easiest to fix out of the above is the valve stem seals. You'll need a cheap tool and new seals, maybe new valve cover gaskets etc... off the top of my head,
I'd say the total cost could be around $50. You can probably get FREE loaner tools from Autozone or Advance Autoparts if you don't want to invest on a valve spring compressor. Make sure the well-used loaner works ok before you sign it out of the store
Being able to feed compressed air into the cylinder via the spark plug hole would help a lot. Adapters should be easy to find. While the cylinder is under pressure (Valves closed), you can listen to hissing sounds from the crankcase, and maybe compare the different cylinders to see if any are leaking pressure more than the others. A proper leakdown test would require a gauge but this is a crude way of guesstimating it.
You will also need to know the install depth for the stem seals. You don't drive them all the way down usually. If the new seals are identical with the old ones, you can use same install height.
Jan
First Prev 2 of 2
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
Hi. I'm new. 98 Cobra Bent Axle.
  • sbk93036
  • Mar 28, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 5, 2026
Mustang5L5
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
