Pull the inlet line on the TB. If you are getting oil in the intake you will see it dripping from the TB plate.
This is what mine looked like.
When the engine is run at low rpm for extended periods, more oil will build up in the intake making more smoke the next time you romp on it.
There are a couple of things that can cause it. Oil can be entering from the pcv, breather line (from TB/VC), and a gasket leak between the lower intake to head gasket. Check that the gasket did not slip down when you dropped the lower intak into place.
To check if oil is entering through the pcv or TB/VC hose, simply pull the hoses and see if the inside of the lines are wet with oil.
If it is entering through the pcv then make sure the baffles are in place. It is worth while to pull the intake for this. Also a seperator can be used to help collect the oil passing through the pcv before it enters the intake. If that still does not work then try putting a 1/8" restrictor between the pcv and seperator.
Also a restrictor can be used on the TB/VC line. This simply reduces the quantity of air passing through the crankcase/pcv system.
If possible don't use the restrictors, as it will limit how well contaminants can be purged from the crankcase.
Hope this helps
jason
