Smoothing out the Engine Bay
  • Thread starter Thread starter vristang
  • Start date Start date Aug 11, 2006
vristang
4,933
101
124
Seattle
Aug 11, 2006
  • Aug 11, 2006
I read a thread on another forum, and a guy had used Bondo to fill in the numerous holes in the engine bay.
It came out looking pretty sweet, but I am concerned what will happen when the chassis starts to flex in a corner or when accelerating.
I may try this in the 2.3 as the motor should be coming out in the next 6mo or so.
Has anyone used Bondo to smooth out the engine bay?
Maybe a more flexible filler would be better?
JB Weld?
How about welding the holes?
Any other options?
Just kicking around ideas.
Thanks,
jason
QDRHRSE
1,590
Palmdale, CA
Aug 12, 2006
  • Aug 12, 2006
Welding the holes and then using a little filler is the only good way to do it.
carbed87
215
  • Aug 12, 2006
correct. they're just holes, so they're not hard to weld in at all. hell, i would even skip on the thin layer of bondo unless it was a hrdcore show car.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Aug 12, 2006
  • Aug 12, 2006
Me as well as a few other guys including Mansonozz have used a product called All Metal. Its a filler like bondo but much stronger. I'm in the process of smoothing out my engine bay right now. I have the filler layed on and sanded down on both sides. In addition to the filler, I'm also using some spot puddy to fill in the little tiny areas that the all metal didn't get.
It's very important to weld up the holes, if you don't weld and only use filler, its going to crack.
ALMOST STOCK
1,250
41
88
CA.
Aug 12, 2006
  • Aug 12, 2006
About 6 yrs ago I welded up the holes in the engine bay. I then used the all-metal as thin filler to fill in the grinding marks from welding and to fill in any low spots to make everything level in the engine bay.
I then shot the engine bay with a etching primer, and the last thing I did was to use the evercoat finishing putty to fill in all the really- really small pin holes that may have been left in the all-metal.
After that I shot the engine bay with a single stage paint.
As I said that way about 6 yrs ago and I never seen a crack in the engine bay.
My theory was to do it once and do it right.
However there is a person on Corral that used some sort of 3M tape and says he’s never had a crack either.
Here is the link.
http://www.corral.net/forums/showthread.php?t=810250
pb_paulie_b
894
Chaptico, Maryland
Aug 12, 2006
  • Aug 12, 2006
I also used the 3M tape. No cracks and my car is not garaged.
Obviously welding is the best but I have no welder or welding skills...PB
RacEoHolic330
4,014
1,698
203
Allentown, PA
Aug 12, 2006
  • Aug 12, 2006
that 3M tape is pretty trick stuff.
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
J
Electrical No crank no dash no nothing, troubleshooting leads to more questions
  • Jojam99
  • Jun 2, 2022
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Jun 2, 2022
Jojam99
J
F
Paint and Body Scott Rod Fab Engine Panels
  • F2Falcon
  • Jan 4, 2020
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 12, 2020
7991LXnSHO
