Electrical SN95 351W 3 plug distributor to a 95 wiring harness stock distributor plug
kevinw40
48390
Can anyone tell me where to hook the 3 wires that I have coming from my older style distributor to my stock 95 wiring harness. I went from a stock 302 fuel injected motor to an older carburated 351W motor with the 3 prong distributor but I still want to keep the original wiring harness so that down the road I can change the distributor to a 94 Lightning distributor that has the same plug as the original 95 stang harness. I just want to get it running now with the old distributor.
  • Sponsors(?)
jozsefsz
5 Year Member
Aug 11, 2013
1,133
264
114
49
Cleveland OH Area
You'll have to describe the older-style distributor a little better. If it's an old points-distributor, you'd go straight to the coil negative lead with an ignition wire (+) going to the coil positive. If it's a 3-prong Duraspark distributor (I'm guessing it is as that's about the only one with 3 wires) you'd need the Duraspark ignition module and wiring harness to it. Either way there's nothing of value in the original 95 harness that an older-style distributor can use, and trying to hook it up will just melt your TFI module.
I'd suggest swapping in a 1-wire distributor as the simplest solution to get you running. As to your future plans, you can't really use the stock computer, ignition module, and a Lightning distributor without bringing over the fuel injection and everything associated with it too. If you're planning to stay carbed, you're going to need to do something different. Can't have the stock computer-controlled ignition that factors in RPM, load, fuel, etc. into setting your timing when you've yanked all the rest of the system out.
Something like this: https://www.cjponyparts.com/proform...u705PUQKmEY0uSraHAgGMe441pk8DEKhoCVKAQAvD_BwE
kevinw40
48390
Totally makes sense now. Thanks for the explanation. I do have the Duraspark distributor, so I did see a wiring diagram online that shows how to wire the Duraspark distributor directly to the coil. Couldn't I just do it that way and use the 95 harness coil wires so that the ignition switch would control the power to the coil?
jozsefsz
5 Year Member
Aug 11, 2013
1,133
264
114
49
Cleveland OH Area
You can wire an older distributor directly to the coil, but only if it's a points-type distributor. If it's a Duraspark distributor it has a pickup inside and a reluctor wheel which sends a signal to the ignition module, which then drives the coil. It won't be able to drive the coil by itself.
kevinw40
48390
so how do you turn the engine on and off using the keyed ignition? I really want the engine to start and shut off using the keyed ignition switch. I have an old harness that the previous owner made up and he was using the large red wire on the engine harness and had it labeled as "Distributor" but when I got the car the engine was already gone and I am not sure what he was doing but it is only 1 wire. So would that go to the 1 wire distributor?
jozsefsz
5 Year Member
Aug 11, 2013
1,133
264
114
49
Cleveland OH Area
This paragraph is for using a stock (points) distributor. The coil + should be hooked up to a keyed voltage source, that'll shut things off when you turn off the key. The distributor controls the ground signal to the negative side of the coil via the points. Not sure with all the other stuff removed if the + wire to the coil + side will continue to function in the stock harness, but I don't know why it wouldn't.
Not knowing anything else about the engine harness the previous owner created, check to see if when-connected it's a + voltage source which turns on & off with the key. If so, you can use that on your coil + side if you're using a points distributor.
If you go with a 1-wire distributor, typically it just requires a + voltage source, keyed, to the distributor input. For that, the same wire would work. But again verify you've got a 12v+ keyed signal on that wire. A test-light or volt-meter will do the trick.
kevinw40
48390
Yes that makes sense. I am going to get the "ready to run" electronic distributor and then make sure I have the keyed power source and I should be good to go. Thanks again, hope to have it running soon. I just got the hooker super comp headers with the BBK off road pipe and a Pypes pipe bomb exhaust so it should be a real treat when I do get it running! I am sure the neighbors will love it!
Thread starter Similar threads Forum Replies Date
Hollywood_Vae Sn95 351w swap 1994 - 1995 Specific Tech 6
Y sn95 351w Digital Self-tuning Forum 3
X 351w sn95 timing cover 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
S '95 Gt Manual Steering Conversion 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
T SN95 Sn95 351w Swap To 408 Stroker 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
T 351w Build Questions In A Sn95 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
S 393w Camshaft & Opinions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
88mustang on a budget Project "blown Budget" 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
Pokageek Less than 3k miles pn Accufab 1 7/8" into 3" LONG TUBES - sn95 351w/stroker Exhaust Parts 1
beaststang SN95 351W SWAP HEADERS?? OOPS THERE GOES THE BALANCER... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
E 351w in SN95. Smog? SN95 4.6L Mustang Tech 13
3 SN95 351W Swap 1994 - 1995 Specific Tech 30
brad mulvey Do BBK 351w swap headers work in sn95? 1994 - 1995 Specific Tech 1
BOOSTED393 351w in sn95 with stock hood? 1994 - 1995 Specific Tech 35
D The definitive SN95 GT to Cobra brake upgrade. Part numbers and pictures. 1996 - 2004 SN95 Mustang -General/Talk- 1
R 1995 Mustang power window does not work. 1996 - 2004 SN95 Mustang -General/Talk- 0
M PCM change for tranny swap? '94 V6 1994 - 1995 Specific Tech 1
Brian 01 Cobra vert SN95 The Welcome Wagon 2
pats91 Paint and Body Floor Pan Replacement - Can a SN95/New Edge floorpan be used in a Fox Fox 5.0 Mustang Tech 4
C SN95 tire size advice 1996 - 2004 SN95 Mustang -General/Talk- 1
G What Tuner to Buy SN95 4.6L Mustang Tech 0
P SN95 rebuild 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
R Engine Explorer upper and lower with egr holes on sn95 gt Fox 5.0 Mustang Tech 5
C Brakes Stock fox front brakes with sn95 rear Fox 5.0 Mustang Tech 8
C S197 vs sn95 front spindle 1996 - 2004 SN95 Mustang -General/Talk- 1
C 1995 Mustang 5.0 HO standalone harness 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
ryansgts 2000 gt e85 conversion? 1996 - 2004 SN95 Mustang -General/Talk- 0
D 95 mustang 5.0 no crank no start, went thru checklist.. 1994 - 1995 Specific Tech 1
beyondEOD SN95 94-95 Microsquirt Pinouts Digital Self-tuning Forum 8
P Fox Has anyone ever used sn95 emission valve solenoids in a foxbody. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
B SN95 Transmission Swap 1996 - 2004 SN95 Mustang -General/Talk- 0
B Spotting the difference between 95 5.0 gt and 5.0 cobra 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 39
beyondEOD Fuel Pressure Sensor with Megasquirt Digital Self-tuning Forum 7
beyondEOD 94-95 Mustang 5.0 AODE MS3 Gold Box w/ Microsquirt Digital Self-tuning Forum 62
C 289 rotating assembly SN95 4.6L Mustang Tech 1
beyondEOD SOLD MOATES QUARTERHORSE QH EEC Tuner Engine and Power Adder 1
beyondEOD 94-95 Mustang GT Auto Dual Microsquirt ECUs Digital Self-tuning Forum 14
M Gt40P headers search for SN95??? 1994 - 1995 Specific Tech 8
C For Sale Moser 8.8 Rearend Drivetrain Parts 0
C For Sale Moser 8.8 Complete Rear End Drivetrain Parts 0
M SN95 SCT PRP Injector Swap 1996 - 2004 SN95 Mustang -General/Talk- 1
J Cobra wheels The Welcome Wagon 1
James V Will SN95 TPS work with Fox ECU? Fox 5.0 Mustang Tech 0
94Vortechcobra Connecting Wideband to Megasquirt PNP2 Digital Self-tuning Forum 0
Levi.Productions 1996 Mustang GT Build (Ew to New) 1996 - 2004 SN95 Mustang -General/Talk- 2
S Best 99-04 Mustang GT clutch kit replacement? SN95 4.6L Mustang Tech 1
G Sn95 coilovers 1996 - 2004 SN95 Mustang -General/Talk- 1
F SN95 351 convertible swap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
9 Saleen wheels What is it Worth?!?!? 1
C New to the SN95 The Welcome Wagon 4
