SN95 8.8, 9", or rebuilt 8" in a 66?
VTStang66
2,407
Rockwall, TX
I'm doing something about my rear end soon. It's an 8" 3.00 open. I see 3 options:
SN95 8.8":
I did a little searching around here and I saw a lot of people complaining about the explorer 8.8s, so I guess if I go the 8.8 route it will be with one out of an SN95. How much wider are they than a '66 8", and what is involved in the swap? Price? Disc brakes are nice.
9":
Where would I get one? Obviously from a junkyard, but from what vehicles? I would probably have to rebuild it with a new LS or locker and some new gears, so price becomes a concern. Disc brakes probably won't happen with this option. Some people would say I need a 9", some would say not.
Rebuild current 8":
I would go with either a locker or limited slip unit from some aftermarket source, and probably 4.10ish gears. This would probably be the cheapest route, but I'm wondering if it's the best idea. Disc brakes are out with this one.
The car is a '66 fastback, ~300 horsepower through a tremec 3550. I'm going to put the wheels from a 2001 V-6 mustang on there (16" aluminum with 225/55/16 goodyears). I need to get wheel adapters to fit them on the car regardless of what I do with the rear, so the width of the rear isn't a huge deal unless it eats up more than 1.25" of backspacing per side (the width of the adapters for a stock 8").
What should I do, and how do I do it?
Just freshen up the 8" that you have now. You won't be breaking it with the power you have. I'd probably go with 3.55's, other than that everything is optional, even the decision whether or not you want a L/S differential.
rebuild the 8" you have now. a 9" is about 75lbs heavier than an 8", and the 8.8 needs extra work to make it fit. as was said, you dont need the 9" as you wont break the 8" even with slicks with your engine combo.
