sn95 A/C Bracket
It's doable for sure, but you may end up replacing some of your accessories. I'm honestly not sure about the interchangability of some components, like the power steering pump. You'll almost certainly need to change your timing cover and water pump.
I was under the impression that the sn95 and explorer motors used the same water pump and accessories. that may be an easier way to get the things that you need...
I don't care that I'd have to replace a lot things most parts on the sn95 are superior anyway like the alternator, powersteering pump, etc. I just want the a/c compressor out of the way I always hated that the line ran right across the intake right in the way. Hopefully someone knows the answer to what is possible and needed to make the swap
