sn95 axles in a fox housing
I did this when I went 5 lug. If you're going rear disc as well, you'll need the caliper brackets and the brake line off the sn95 housing to mate up with the sn fittings on the calipers.
Otherwise, I think they sell a brake line to adapt the fox hard line to the calipers.
if you're not concerned about going with rear disk brakes, I suggest you take a look at one of the many budget 5-lug conversion kits out there right now. Late Model Restoration sells a complete 5-lug kit, including fluids for under $390. It's not ever work driving to the various wreckers to scrounge for parts at that price.
If your wanting to do this for the 5 lug conversion, get the 2 LEFT side axles out of a ranger, plus they are stronger!
Did it back in the day on my 93 vert.
:scratch:.....what's exactly is suposed to make them stonger? They're the same 1040 grade 28-spline carbon steel axles the stock 4-lug and 4-lug Mustang versions are? It took next to no effort for me to twist one off with my old 5.0L powered Ford Ranger back in the day....it it didn't even make that much power? :shrug:
The ones I used were 31 spline. thats what makes them stronger. its been over 15 years ago I done that, I dont remember what year they came out of. Another guy I know went 9's on ford ranger axles,so I dont know how you broke yours so easily.
You can also run stock length 5 lug axles with the factory GT disc brake brackets. You have to cut a section out of the bracket so it slides over the opposite side of the rear end housing.
Ahh, it that case, I agree. The '02-up FX4 31-spine axles are stonger, but those aren't the ones that everyone is talking about swapping over for the "budget" 5-lug swap. The ones being discussed (or at least that was my impression) are the standard 28-spline left side Ranger axles that are a direct swap into the stock Mustang diff. The 31-spline axles won't work unless you upgrade t0 a 31-spline differential as well.
I'm assuming your friend went 9's with the 31-spline units? Because if he did it with the 28's, he didn't do it for long. I twisted one off going spinning from gravel, onto pavement in my '85 4x4 with 31x10.5" tires. The stock 28-spline axles (Mustang, Ranger or otherwise) have never been known for being overly "tough".
Yes , you are right friend, I guess I should have clarified that!!sorry about that!
I have a question for this one. I understand that the sn95 axle will fit a fox since they are all 8.8 rear ends. But everyone was talking 86-93 fox. My question is, is there a difference with a 85 fox? Will everything still fit?
Yes, 94-98 Axle shafts and brakes will fit a 1985 7.5" housing. The 7.5" axle was also used in those year V6 Mustangs.
