sn95 spindles
  • Thread starter Thread starter 86'4:10C-4
  • Start date Start date May 25, 2006
86'4:10C-4
10
northglenn,Co
May 25, 2006
  • May 25, 2006
hi. i drive an 86 mustang gt and i am planning on changing my front spindles calipers and rotors to sn95 stuff. i know the ball joints are a little different...i was hoping to get some advice on how to go about doing the swap...and what i should do to get over some of the problems...anything helps...
KENS89LX
302
Cross lanes Wv
May 26, 2006
  • May 26, 2006
Any sn-95 model spindles will work but you need the brake line screw that goes in to the caliper off the sn-95 because the threads are different on the fox body. If you use spindles off of a v-6 I'm told you need to use that strut also. Hope that helps!
trbkrb
1,976
Houston, TX
May 27, 2006
  • May 27, 2006
Well, the best source for info is http://sn95brakes.com
You need a spacer for the ball joint or SN95 ball joints, and your struts have a wider opening than all of the SN95 spindles, v8 and v6. So you either need newer struts (87-93 V8 struts) or you need a spacer in between spindle and strut to fill the opening. Washers might work, but some struts come with metal spacers.
There are several other sites with more install info, but I don't have them marked on this PC. Do a search on brakes and you should find some.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
