SN95 TB on a Fox 5.0? need to make it work
r.barn5.0
107
Ok, I'm having hood clearance issues with my 351W install
where the CAI tube comes off the TB.
Now a SN95 TB adaptor that twists and lowers the TB would
work perfect, but I noticed the SN95 uses different shaped throttle bodies
Can I use an SN95 TB with my 5.0 electronics?
What is the difference between the two besides shape?
just do the complete opposite what we do for the fox TB conversion.
you will need to swap out the throttle body, throttle body bracket, tps, iac, throttle cable, and if you want to keep crise control, the cable. the connector on the tps on the main harness is different so you need to get the different pig tail. i forget which color combination the wires are supposed to be but just do a search and you'll find out.
good luck
