  • 1994 - 1995 Specific Tech
snap, crackle pop!
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Nov 4, 2007
DDSTANG94
465
FRASER, MICHIGAN
Nov 4, 2007
  • Nov 4, 2007
When i go over bumps i hear noises under my car that sounds like a crackling or metal hitting something, its almost like a popping sound...any ideas?
94mustangcobra
126
Valdosta, GA
Nov 4, 2007
  • Nov 4, 2007
spring isolators maybe?? upper and lower control rubber bushings worn out ??
HISSIN50
34
129
Nov 4, 2007
  • Nov 4, 2007
Since it's bump related, it can also simply be loose end links. They take 7.2 seconds to check (do it with the car flat on the ground).
Good luck.
SuperStang83
1,693
Boyertown, Pa
Nov 4, 2007
  • Nov 4, 2007
Could also be the smog pipe hitting the exhaust. It is a long shot by the sounds you are describing, but it is wirth a look, and only takes 4.2 seconds to check.
DDSTANG94
465
FRASER, MICHIGAN
Nov 4, 2007
  • Nov 4, 2007
how?
Good luck.
How do u check this...suspension stuff is not me...
D
Daggar
3,902
  • Nov 4, 2007
Stock suspension components?
DDSTANG94
465
FRASER, MICHIGAN
Nov 4, 2007
  • Nov 4, 2007
yup
D
Daggar
3,902
  • Nov 4, 2007
Ok... that pretty much rules out suspension bind then.
HISSIN50
34
129
Nov 4, 2007
  • Nov 4, 2007
With the car on the ground, just reach around under the car and wiggle the end link. If it's loose, it will make noise (tink tink or clank clank). If you can get your head under the car, you can see how squished the end-link bushings (they look like little donuts) are. If they are not a little squished, the end link can make noise.
The AIR discharge-pipe hitting the exhaust was a good suggestion too.
Good luck.
DDSTANG94
465
FRASER, MICHIGAN
Nov 4, 2007
#10
  • Nov 4, 2007
  • #10
SuperStang83 said:
Could also be the smog pipe hitting the exhaust. It is a long shot by the sounds you are describing, but it is wirth a look, and only takes 4.2 seconds to check.[/QUOTE
Ok ill take a look..is this the pipe that goes from the smog pump to the h pipe? im not to sure on this one neither....thanks man!
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 4, 2007
#11
  • Nov 4, 2007
  • #11
Check your balljoints out, too. Toss the front end on some jackstands and grab the tire at the top and bottom and see if it rocks. You should put the jackstands under the control arms to simulate suspension loading. If the tire deflects, you're probably looking at a balljoint replacement and picking up some 03-04 Cobra control arms with new balljoints already pressed in (plus new bushings) wouldn't be a bad idea.
DDSTANG94
465
FRASER, MICHIGAN
Nov 4, 2007
#12
  • Nov 4, 2007
  • #12
this was exactly what i was planing on doing, that's how my dad told me to check...thanks man
SuperStang83
1,693
Boyertown, Pa
Nov 4, 2007
#13
  • Nov 4, 2007
  • #13
Yeah smog pump to the passenger side of the h-pipe.
DDSTANG94
465
FRASER, MICHIGAN
Nov 6, 2007
#14
  • Nov 6, 2007
  • #14
PUNISHER RACING said:
header bearings maybe?
what are them?? lol
BlownFiveLiter
18
108
Chicagoland
Nov 7, 2007
#15
  • Nov 7, 2007
  • #15
DDSTANG94 said:
what are them?? lol
A smart assed deleted post
Dino Dino Bambino
1,673
90
79
Cyprus
Nov 7, 2007
#16
  • Nov 7, 2007
  • #16
DDSTANG94 said:
When I go over bumps I hear noises under my car that sounds like a crackling or metal hitting something, its almost like a popping sound...any ideas?
The following come to mind:
1. Worn end links +/- front anti-sway bar bushings.
2. Worn inner/outer tie rod ends.
3. Worn ball joints.
4. Worn control arm bushings.
I have a different noise coming from my Stang when I go over bumps or when I'm slowing down but I'll post mine in a new thread instead of hijacking this one.
DDSTANG94
465
FRASER, MICHIGAN
Nov 7, 2007
#17
  • Nov 7, 2007
  • #17
alright thanks guys, ill check ill check it out!!
DDSTANG94
465
FRASER, MICHIGAN
Nov 7, 2007
#18
  • Nov 7, 2007
  • #18
thats what i thought ..thanks
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 18, 2026
TPony
